3 Out 5 Burners Will Light On Tempstar - HVAC - DIY Chatroom Home Improvement Forum
Old 12-04-2010, 01:40 PM   #1
3 out 5 burners will light on tempstar
I have a tempstar furnace, we were smelling gas in the house so I turned it off. I went outside and took the cover off and noticed that only 3 of the 5 burners are lighting. The other two will light with a lighter. I unscrewed the jet and there is no obstruction. Any help will be appreciated.
jtucker9 is offline   Reply With Quote
Old 12-04-2010, 02:13 PM   #2
AKA HVACTECHFW
Rewards Points: 1,208
clean the burner ends with a steel brush, all of them
hvactech126 is offline   Reply With Quote
Old 12-04-2010, 02:36 PM   #3
Working on that right now, just came in to see if I got a reply, thanks. They don't look very bad at all but I am trying it anyway, will let ya know if it works.
Old 12-04-2010, 02:40 PM   #4
AKA HVACTECHFW
while they are out, check orfices on manifold for spiders and bugs
Old 12-04-2010, 02:50 PM   #5
Hvac Pro
yuri's Avatar
Rewards Points: 396
Blow the burners out with compressed air and then rinse them in the sink with hot water. Check the slots in them for rusting. blockage and clean them carefully with a screwdriver or hacksaw blade (carefully) or other thin object.
Old 12-04-2010, 02:59 PM   #6
AKA HVACTECHFW
Originally Posted by yuri View Post
blow the burners out with compressed air and then rinse them in the sink with hot water. Check the slots in them for rusting. Blockage and clean them carefully with a screwdriver or hacksaw blade (carefully) or other thin object.
do not pry them open!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!
Old 12-04-2010, 03:34 PM   #7
Thanks a lot, cleaned them with a wire brush really good and just tried it and all is working, THANK YOU very much. I appreciate the advice.
Pilot light button on furnace won't turn whydonchathen HVAC 8 01-19-2015 10:40 AM
Ceiling Fan with Light kit - Light not working aadams Electrical 12 11-03-2010 06:32 PM
Grout question poolecw Flooring 11 10-29-2008 07:32 PM
Marmoleum repairs muggyfrost Flooring 8 10-16-2008 08:19 PM
