3.5ton Evap With 4 Ton Compressor - HVAC - DIY Chatroom Home Improvement Forum
Old 06-15-2013, 12:56 PM   #1
Rewards Points: 150
3.5ton evap with 4 ton compressor
Hey I have got a chance to get a free 4 ton compressor, but my old one is 3.5 and not keeping the house cool on a 90 degree day. I know this is a mismatch and dont do it, but why? It seems to me the compressor wold maybe flood the evap ( I have no clue is this is TXV or piston). Can this be done if I adjust the superheat to make sure it doesn't flood the evap? Air flow is great so that shouldn't be a problem. And if this could be done, would I have to change the piston or cap tube?
wetbar is offline   Reply With Quote
Old 06-15-2013, 04:41 PM   #2
An old Tradesmen
Rewards Points: 7,816
Air flow is great? Guessing you mean it blows out the registers hard. Often this is a sign that you don't have enough air flow.
Your suction will be low and cause the coil to freeze up. Adjusting a TXV for more super heat will cause it to freeze quicker.
Using the proper sized TXV or piston will flood the coil, and cause liquid flood back to the compressor.
15 degree split, scroll compressor is hot!! bobinphx HVAC 1 06-05-2013 04:30 AM
Air Compressor Fittings - Differences? roasted Tools 3 09-19-2012 08:15 PM
Help assembling compressor jfhspike Tools 5 03-27-2011 10:07 AM
Air compressor and framing nailer for DIY ADKstorm Tools 20 11-11-2010 07:38 AM
New Compressor - Wrong Charge? shayneb HVAC 4 08-23-2008 08:13 AM
