3 Or 4 Ton Geothermal - HVAC - DIY Chatroom Home Improvement Forum
Old 02-14-2013, 01:23 PM   #1
3 or 4 ton Geothermal
I had 2 quotes from installers for a Waterfurnace 7 series geothermal unit. One says that my 8" x 22" duct work can handle the 1600 cfm required (according to the manufacturer). my question is can my duct work handle 1600cfm?
MrEnte is offline   Reply With Quote
Old 02-14-2013, 01:24 PM   #2
my duct work is 8 x 22
Old 02-14-2013, 02:48 PM   #3
Missouri Bound's Avatar
What are you using now? What size furnace, how large is your home? If the current system is the same size as what you are replacing it with....why would you think it would be a problem.
Do you want it your way or the right way?
Old 02-14-2013, 08:31 PM   #4
An old Tradesmen
Rewards Points: 6,116
is the current unit in the middle of the basement so that the 8X22 is running from 2 sides of it. or is the current unit at one end of the house and you have a single 8X22 trunk line. 8X22 is too small for 4 tons. It will make for a loud system.
Geothermal heat pump using pool as heat sink mnschu HVAC 9 05-17-2012 09:10 PM
Geothermal heating/cooling? Badfish740 HVAC 6 03-15-2012 09:43 AM
Geothermal recovery against house foundation dirtman HVAC 0 01-05-2011 02:54 PM
Geothermal cold air returns mighty mouse HVAC 12 01-11-2010 06:08 PM
Electric heat prices vs. geothermal mss119 HVAC 23 04-07-2009 08:23 PM
