3/4 Inch Hardwood With Under Floor Radiant Heat - HVAC - DIY Chatroom Home Improvement Forum
Old 03-15-2009, 08:16 PM   #1
3/4 inch hardwood with under floor radiant heat
I know it is not recomended, but i have heard of it being done. companies suggest not using it but i like the look and feel of soild wood. I have read where if you dry out your subfloor before installation you shoud be ok and also aclimate your flooring very good. Does anyone have any bad experiences with warping, cracking, spreading etc?? I would not be looking at the real wide plank floor just your already finished bruce flooring in #2 grade becasue i like the little knots and stuff???
Jb#24 is offline   Reply With Quote
Old 03-15-2009, 08:23 PM   #2
An old Tradesmen
Rewards Points: 6,944
The floors generally warp because people run the floor temp too high.
Old 03-15-2009, 08:29 PM   #3
Maybe 'cause wood is a very good insulator. This seems counterproductive.
Old 03-15-2009, 08:39 PM   #4
An old Tradesmen
Wood isn't really a good insulator.
A log cabin's wall has a very low R value for its thickness.
Many people want there floors to be very warm.
Wood floors dry out quickly when they are heated above 87F.
Old 03-15-2009, 08:44 PM   #5
I stand corrected.
http://www.engineeringtoolbox.com/th...ity-d_429.html
Plank subfloor and 3/4 inch prefinished hardwood... wackjaw Flooring 2 02-15-2009 02:49 PM
How to test apartment Heat Pump tbrubes HVAC 7 02-04-2009 03:05 PM
Heat Pump Woes Zenica HVAC 50 01-27-2009 07:37 AM
Adding Radient Heat to Hardwood Floors jimmyfloyd Flooring 6 11-25-2008 03:41 PM
Cracked Heat Exchanger SusanB. HVAC 12 10-14-2008 03:57 PM
