2nd Opinion On Air Return Location - HVAC - DIY Chatroom Home Improvement Forum
Old 02-27-2010, 01:13 PM   #1
2nd Opinion on Air Return Location
Hi guys,
I had an HVAC contractor in about adding a 2nd air return in the basement, and I am unsure if what he suggested is fine, or if it was simply the easiest.
He suggested using the wall cavity to bring it down to the floor, then running a 6" or 7" duct (tbd) back to the main plenum. I am concerned the grill, although in the hall, is next to the utility room door. Does that present any issues? The door would, of course, always be closed and the utility room is a fair size. I just wanted second thoughts on if it could pull air incorrectly or not (ie back from util room). If there is no issue there, the location is otherwise great.
I have a quick diagram below to help:
jsherry is offline   Reply With Quote
Old 02-27-2010, 01:20 PM   #2
that will work fine
mhoy9 is offline   Reply With Quote
Old 02-27-2010, 05:10 PM   #3
An old Tradesmen
Rewards Points: 8,236
Does that utility room have a combustion air intake for the furnace and water heater.
If so. Your ok.
Old 02-27-2010, 09:23 PM   #4
Yes, it does. Its only a 7 year old house and up to current code.
Should I have let the ac guy close off a return? windowman3 HVAC 4 09-13-2009 08:23 AM
return air honola HVAC 11 08-13-2009 07:41 AM
HVAC return vent location question fatboy HVAC 1 03-10-2008 08:56 PM
Basement Return Location handy man88 HVAC 2 10-31-2007 06:53 PM
Central Air return duct location backpacker2 HVAC 3 05-28-2007 10:07 AM
