275 Gallon Fuel Oil Tank Tampering - HVAC - DIY Chatroom Home Improvement Forum
Old 05-15-2012, 05:38 PM   #1
Rewards Points: 528
I have an above ground tank with a valve on the bottom to better remove water accumulation. But this tank is subject to vandalism if someone came along with a pipe wrench and remove the pipe cap on the valve. Is there a solution to prevent tampering?
rjordan392 is offline   Reply With Quote
Old 05-15-2012, 06:32 PM   #2
An old Tradesmen
Rewards Points: 6,590
Not really.
Old 05-15-2012, 07:12 PM   #3
Ravenworks's Avatar
They make locking valves,ask your oil supplier.
Ravenworks is offline   Reply With Quote
The Following 2 Users Say Thank You to Ravenworks For This Useful Post:
plummen (05-16-2012), rjordan392 (05-15-2012)
Old 05-15-2012, 08:23 PM   #4
Rewards Points: 582
locking wing stop....its a flathead stop with a lock hole you can lock in closed position....could try ace hardware.....ben
The Following 2 Users Say Thank You to ben's plumbing For This Useful Post:
Old 05-15-2012, 08:32 PM   #5
An old Tradesmen
Can I turn the thing out of the tank with a pipe wrench.
Old 05-15-2012, 08:43 PM   #6
Rewards Points: 528
Beenthere,
I was thinking the same thing. maybe a lock can be put on the valve but I think there is enough room to turn the whole assembly right out of the threaded hole in the tank. its dark now, I'll check it again tomorrow. If thats the case I may have to brick it in and then install the locking device. the tank is on a cement pad and it would be easy enough to mortor some bricks in. Anyone trying to tamper with this setup would have to make some noise doing it.
Old 05-15-2012, 08:46 PM   #7
Rewards Points: 582
not sure how much room you have only need 1 1/2 clearance....I have taken many off tight areas.... pics would help...
Old 05-15-2012, 08:52 PM   #8
Rewards Points: 528
I'll take a few pictures and post them tomorrow.
The Following User Says Thank You to rjordan392 For This Useful Post:
ben's plumbing (05-15-2012)
Old 05-16-2012, 03:07 PM   #9
Rewards Points: 528
Here are pictures of the valve that needs some type of security to prevent vandals from tampering with it. If I brick this area around the valve, leaving the front open; and then install a locking device; i think this will work. I realize anything can be tamper with; but the idea here is to make it difficult to tampering without making some noise which will attract myself or a neighbor.
275 Gallon Fuel Oil Tank Tampering-003.jpg   275 Gallon Fuel Oil Tank Tampering-004.jpg
Old 05-16-2012, 08:53 PM   #10
Rewards Points: 582
yep should be able to screw locking wing valve on...ben
Old 05-16-2012, 09:09 PM   #11
Rewards Points: 528
Thanks,
I'll check out the locking wing valve and what my local oil distributor has and then pick the one that appears most secure.
ben's plumbing (05-16-2012)
Old 05-17-2012, 07:37 PM   #12
Rewards Points: 528
Ben's Plumbing,
I tried Ace hardware on the net and my search came up empty and I also tried Lowe's. Do you know of a website where I can take a look at the locking wing stop or locking wing valve? The only thing I found on the net was a lock for the fill pipe.
Old 05-17-2012, 08:02 PM   #13
concretemasonry's Avatar
Rewards Points: 2,578
rjordan -
That must be a newer (less than 15 years old) tank since every home in Levittown, PA came with a buried tank and a willow tree. The oil distributors ruled because the guaranteed the tanks as long as you bought oil from them. My wife grew up there and had to deal with the buried problems when her parents passed on and they had not bought enough oil recently.
You may have to go through an oil distributor for the security valve that fits the tank you have. You may pay more, but you will have peace of mind regarding the oil.
Dick
concretemasonry is online now   Reply With Quote
Old 05-17-2012, 08:06 PM   #14
Rewards Points: 582
Ben's Plumbing,
go to wwwgrainger.com type in locking wing valve...should find what your looking for....ben
The Following User Says Thank You to ben's plumbing For This Useful Post:
rjordan392 (05-17-2012)
Installation and support of water heater expansion tanks. Homerepairguy Plumbing 46 01-28-2013 06:55 AM
A.O. Smith Vertex vs Vertex 100 vs 75 gallon tank. TopRowSeat Plumbing 7 01-11-2012 04:15 PM
Septic tank missing T and badly angled main line? denemante Plumbing 3 11-22-2011 10:29 AM
Nightmare water tank job Marvin Gardens Plumbing 6 11-04-2008 12:09 PM
fuel leak where filter line meets tank line sonofthetonsured Automotive Repairs 2 04-22-2008 09:11 AM
