25 1/2 Year Old Water Heater - HVAC - DIY Chatroom Home Improvement Forum
Old 02-22-2013, 06:23 PM   #1
Rewards Points: 874
25 1/2 year old water heater
Me and my wife purchased this house about 6 years ago. Well I have been DIY crazy lately driven by both lack of $$ and passion. I wanted to do some maintenance on my gas boiler and water hear this weekend. I read up on it and watched some videos so I was gonna start with a flush of my water heater and maybe replace the anode rod. Well I was just downstairs and there was an inspection sticker on there(see pics). Not sure what to do but from what I read hot water heaters usually last about 20 years(this is a Rheem). The heat and hot water work fine but I assume this will be crapping out in the near future. Should I still do the maintenance or because its so old it might do more harm than good? Thanks.
25 1/2 year old water heater-photo-6-.jpg
Mstrlucky74 is offline   Reply With Quote
Old 02-22-2013, 06:49 PM   #2
Rewards Points: 948
You are supposed to test the TP valve every year. No one does, but you are supposed to. I tested it on my 12 year old water heater and it wouldn't close completely.
If you catch my drift.
Personally I wouldn't want a 27 year old water heater in my house.
Toller is offline   Reply With Quote
Old 02-22-2013, 07:02 PM   #3
Roofmaster
Rewards Points: 2,172
Boy, that is a great advertisement for Rheem. That is a great run for a Water Heater. Go ahead and drain off a couple of buckets after you get a replacement in the on deck circle.
Is there a sediment filter or neutralizer in line before the WH? Are you on city or well water?
Is there a receipt in there? Id love to see that.
Old 02-22-2013, 07:31 PM   #4
Rewards Points: 54
Dont waste the time, replace it and get peace of mind and clean hot efficient water!
JMO
digitalplumber is just a name for use here, I am not a plumber!
digitalplumber is offline   Reply With Quote
Old 02-22-2013, 07:40 PM   #5
Rewards Points: 874
Sediment or neutralizer filter in line?? You mean as part of the system? I would not know what it looked like. We are on town/county water.
Old 02-22-2013, 07:49 PM   #6
how
Rewards Points: 1,104
Light incense & pay homage to the aged one but
Don't touch it unless you want to replace it.
My business profits nicely from folks touching old HWT's.
how is offline   Reply With Quote
The Following User Says Thank You to how For This Useful Post:
oh'mike (02-23-2013)
Old 02-22-2013, 07:55 PM   #7
It's possible it might do more harm than good. You won't know until you try.
However, I would be standing by with a new one just in case everything goes to crap for you while your doing the maintenance on it. In my opinion, I would replace it as soon as possible. I don't know how much hot water you need, but you can pick up a short 40 at sears for 399 this weekend only. Of course that would be another 400 or so to have it installed by a lincensed plumber. In NY state; boilers, furnaces, and hot water heaters have to be installed by a lincensed professional to obtain their 10 year waranty and also your home owners insurance requires it as well. Home owners cannot install these items, unless of course, the home owner is a lincensed professional.
How many plumbers out there are just shaking their heads right now. Wow! that is fantastic. 25 years of service. Good for you brother.
If you go ahead with the maintenance of it, let us know how it worked out for you. Thanks.
jmon is offline   Reply With Quote
Old 02-22-2013, 08:30 PM   #8
Rewards Points: 874
Thanks all....I'm leaning towards not doing the flush etc. I guess I will just wait until my hot water runs out...lol. I have no idea what these cost....I'm going to web search now..uh oh!!! Now I'm worried about the boiler.
Old 02-22-2013, 08:39 PM   #9
Rewards Points: 582
yep agree with how....don't touch it ..wait till it breaks..if its working fine let it shineben sr
The Following User Says Thank You to ben's plumbing For This Useful Post:
Mstrlucky74 (02-22-2013)
Old 02-22-2013, 09:22 PM   #10
That's only one of two things that could happen. It could also start leaking. Depending on where it is and what kind of damage it could do if it did, I'd replace it.
hvac benny is offline   Reply With Quote
The Following User Says Thank You to hvac benny For This Useful Post:
Mstrlucky74 (02-23-2013)
Old 02-23-2013, 12:17 AM   #11
Rewards Points: 484
Wow, they dont last like that in Vegas. We've been in our house for seven years and we're on our second one already.
sammy37 is offline   Reply With Quote
Old 02-23-2013, 12:40 AM   #12
how
sammy37
Check your water pressure. The higher it is over 70 PSI, the shorter the stat lifespan.
Old 02-23-2013, 06:34 AM   #13
Rewards Points: 1,216
I wouldn't do anything to it.
I would buy a new one with new valves and whatever I would need to replace it and have it ready to install at anytime.
No Warranty Means- If it breaks in half you get to keep both halves.
COLDIRON is offline   Reply With Quote
The Following User Says Thank You to COLDIRON For This Useful Post:
Old 02-23-2013, 07:55 AM   #14
Rewards Points: 874
Is this a DIY project? Maybe me and a bud or two? And some Buds
Thanks.
Old 02-23-2013, 07:58 AM   #15
Rewards Points: 874
We actually have two water heaters and two boilers. I have a 1st floor apartment. The other is an AO Smith. I am wondering how old the boilers are. Based on my research last night those are thousands of dollars. There is no slitting your throat emoticon??? JK, thanks a lot for all the advice.
water heater drip kdange1 Plumbing 6 10-29-2014 05:26 PM
Multiple hot water heater issues a-6intruder Plumbing 8 01-16-2009 05:58 PM
low hot water pressure angus242 Plumbing 10 01-08-2009 11:41 AM
