24volt Wiring Question - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 07-23-2013, 02:59 PM   #16
Originally Posted by raylo32 View Post
Is there a label on the radio control box that names the wires? It would help the guys here if you would post pictures.
PEPCO came around and wanted to install one of those on mine and I declined. I just set my a/c back with the thermostat during the day and don't want them mucking with it.
DTE is threatening to shut my service off if I don't get these wires re-connected and I can't afford to hire an electrician. How do I post a picture? No there is no label either.
markharmon is offline   Reply With Quote
Old 07-23-2013, 03:01 PM   #17
Originally Posted by qbert View Post
They two wires from the utility go in series with the control wire from the thermostat to the contactor. best to call someone out as the utility owns the that device. any hvacr guy should be able to help
I can't I dont have any money. Can you help me?
Old 07-23-2013, 03:11 PM   #18
raylo32's Avatar
Rewards Points: 1,290
How did the wires get disconnected? This thread talks describes how to post pictures using Photobucket. I find this to be the easiest and it works really well.
Condensation all over floor at furnace
Live long and prosper.
raylo32 is offline   Reply With Quote
Old 07-23-2013, 03:44 PM   #19
I have no idea how they got disconnected.
Old 07-23-2013, 03:50 PM   #20
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,968
Just call the POCO. They probably have folks to work on this stuff. The equipment is theirs anyway.
As you've been told several times already in this thread. Most electricians do not work on this equipment.
Old 07-23-2013, 04:44 PM   #21
what is POCO?
The Following User Says Thank You to markharmon For This Useful Post:
QueBall (07-23-2013)
Old 07-23-2013, 05:17 PM   #22
Originally Posted by markharmon
what is POCO?
POwer COmpany
clydesdale is offline   Reply With Quote
Old 07-23-2013, 06:37 PM   #23
Somebody disabled the shut off 24 v circuit.
When the power co gets into a brown out situation your meter will shut off your ac to help relieve the brown out conditions.
They usually do so for for about twenty minutes at a time. They give a discount on your rate in return for turning off your ac meter for a short time.
So you are getting the discounted rate but your ac cannot be turned off by the power company snce the wires you mention are dis connected.
hvac5646 is offline   Reply With Quote
Old 07-23-2013, 06:49 PM   #24
I can help.
Where are the disconnected wires and what color are they?
Old 07-23-2013, 06:49 PM   #25
Old 07-23-2013, 07:14 PM   #26
biggles's Avatar
all they are doing is breaking your 24V to your system not supplying it...you have a stat right?R red hot 24v primary...y /yellow./cool.. G/green/FAN ...w/white/heat ...they are breaking the RED normally closed open on their command thru their control ...remove the pair on the NC points and wire nut them together...doubt they are controlling the fan cooling and heat?once they break the R/red the show shuts down
Old 07-23-2013, 07:32 PM   #27
Congrats...u just blew the RC xfmr.
Old 07-23-2013, 08:53 PM   #28
An old Tradesmen
Rewards Points: 7,746
All your threads on this have been merged into this one. Please don't make duplicate threads. thank you.
Old 07-24-2013, 11:16 AM   #29
dmclean701's Avatar
Rewards Points: 152
PG&E has been trying to get these installed by sending out a $50 rebate and telling customers the box will cause your AC to "use less energy", but it won't turn your AC off. When I questioned them about this by email they admitted the radio control opens the contactor to stop the compressor. Thus it uses less energy. I asked if they thought this was misleading; telling people it won't turn off the AC. They said "well the blower is still running". I offered the analogy that it was like saying we don't stop your car we just turn off the engine. They didn't see the logic of this at all, but I suppose I was talking to public information flacks not technical people. I declined to have one also.
Sent from my iPad using DIY Forum
dmclean701 is offline   Reply With Quote
The Following User Says Thank You to dmclean701 For This Useful Post:
gregzoll (07-24-2013)
Old 07-24-2013, 03:10 PM   #30
as seen on tv
Rewards Points: 150
In this area the utility only credits customers 10 bucks and ther is only a few around. Had to hook up one on new system install this spring
qbert is offline   Reply With Quote
208V/3 Phase Wiring Question efalcon1 Electrical 12 09-28-2012 11:22 AM
Outdoor Wiring Question OKDrew63 Electrical 30 08-14-2012 11:25 PM
Adding 2 outlets in the middle of a series of outlets - wiring question Evan55 Electrical 7 06-14-2012 09:43 AM
Attic wiring question everyman Electrical 4 07-07-2009 09:47 AM
Trane Heat Pump tstat replacement with Honeywell prog - wiring question sep23 HVAC 2 10-20-2006 09:10 PM
