24volt Wiring Question - HVAC - DIY Chatroom Home Improvement Forum
Old 07-22-2013, 04:48 PM   #1
A/C Interrupitble meter question
Hello,
For some reason our a/c interruptible wires are disconnected. If someone could help me understand I would appreciate it. Above the meter for the a/c is an enclosure with thermostat wire. There red, blue, white and green. It goes to a box above which I would believe is the radio device which just has a blue and red wire leading to the box below. Can someone please tell me how to connect these wires to which?
markharmon is offline   Reply With Quote
Old 07-22-2013, 05:29 PM   #2
An old Tradesmen
Rewards Points: 6,886
Someone probably disconnected them because they got tired of not having A/c when its 95 outside.
Should be a diagram there on teh box. i haven't messed with one for a while, so i don't remember what wires where.
Old 07-23-2013, 11:25 AM   #3
A/C Meter
Hello,
Old 07-23-2013, 11:48 AM   #4
Rewards Points: 6,652
Do not have a clue what you are talking about. Post some pictures of the issue at hand.
Old 07-23-2013, 01:39 PM   #5
Hello,
Old 07-23-2013, 01:59 PM   #6
Electrical Contractor
jbfan's Avatar
Rewards Points: 386
That should be the POCO's thing to do.
I've never seen what you are talking about myself.
I know what you are talking about now.
I have never been inside either.
jbfan is online now   Reply With Quote
Old 07-23-2013, 02:06 PM   #7
Licensed electrician
Rewards Points: 1,486
Agreed, that is a radio controlled switch installed by your power company. During periods of high demand they can cycle off your A/C to shed load on the system.
Old 07-23-2013, 02:08 PM   #8
Can you please tell me which 24 volt wires get connected from the radio control unit to the 24 volt wires coming from the a/c?
Old 07-23-2013, 02:13 PM   #9
No, I can't. I have never seen the inside of one. As stated above, they are installed by the power company.
Old 07-23-2013, 02:24 PM   #10
i have a/c interruptible service
but they noticed
that the 24 volt wires are disconnected
there are 4 wires coming from the a/c unit
and 4 wires coming from
i just need to know which color wires get connected to which
Old 07-23-2013, 02:28 PM   #11
24volt wiring question
If someone can help I would really appreciate.
but they noticed
Old 07-23-2013, 02:47 PM   #12
raylo32's Avatar
Rewards Points: 1,254
Are you talking about a setup the utility installed to be able to cut off your a/c remotely during times of extremely electricity high demand?
Live long and prosper.
raylo32 is online now   Reply With Quote
Old 07-23-2013, 02:48 PM   #13
Yes I am.
The Following User Says Thank You to markharmon For This Useful Post:
gregzoll (07-24-2013)
Old 07-23-2013, 02:50 PM   #14
as seen on tv
Rewards Points: 150
They two wires from the utility go in series with the control wire from the thermostat to the contactor. best to call someone out as the utility owns the that device. any hvacr guy should be able to help
qbert is offline   Reply With Quote
Old 07-23-2013, 02:57 PM   #15
raylo32's Avatar
Is there a label on the radio control box that names the wires? It would help the guys here if you would post pictures.
PEPCO came around and wanted to install one of those on mine and I declined. I just set my a/c back with the thermostat during the day and don't want them mucking with it.
208V/3 Phase Wiring Question efalcon1 Electrical 12 09-28-2012 11:22 AM
Outdoor Wiring Question OKDrew63 Electrical 30 08-14-2012 11:25 PM
Adding 2 outlets in the middle of a series of outlets - wiring question Evan55 Electrical 7 06-14-2012 09:43 AM
Attic wiring question everyman Electrical 4 07-07-2009 09:47 AM
Trane Heat Pump tstat replacement with Honeywell prog - wiring question sep23 HVAC 2 10-20-2006 09:10 PM
