24VAC Common For New Thermostat - HVAC - DIY Chatroom Home Improvement Forum
Old 03-02-2012, 11:35 PM   #1
24VAC Common for New Thermostat
I have a Goodman GMT115-5B furnace and outside condenser:
The cable to our thermostat has 5 wires with the Red, Yellow, Green, and White being used by the thermostat. The 5th blue wire is unused at both the thermostat and at the furnace.
My new thermostat (Honeywell TH8320ZW100 Z-Wave) requires a 5th wire for 24VAC Common:
Here are some pictures of the board in the furnace:
Here is what I found on Goodman thermostat wiring:
This is how I'm currently wired:
I have an unused 5th (blue) wire in the cable to my thermostat location. I just need to know where to hook it up at the furnace. Can anyone point me in the right direction?
Thanks!
breezin is offline   Reply With Quote
Old 03-03-2012, 12:02 AM   #2
GC/Master Plumber/Mech
Rewards Points: 560
If you look in the wiring diagram you see the Chasis ground this will be your C connection. Goodman is a cheap furnace in my opinion and they most of the time use the furnace case as ground instead of providing a terminal connection
Thanks!
Look above for red type
John Wayne once said "Life is tough and it is even tougher if you are stupid"
Tempstar and Trane Dealer
Old 03-03-2012, 12:13 AM   #3
So I would attach the unused blue wire at this point:
Thanks again for the advice!
Old 03-03-2012, 07:11 AM   #4
AKA HVACTECHFW
Rewards Points: 1,208
yes, attach the wire at the point
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Old 03-03-2012, 08:09 AM   #5
biggles's Avatar
see that "powder blue" right off the TR is the common side of the 24V up to the stat that is a constant as long as the furnace has power....you want to read R to C on the stat subbase.reason they call for a C the stat is digital electronic w/LEDS the old feedback trick won't do it.if you hook it up without the TRUE 24Vs it will only light up,but have no action to the furnace or condenser.anyone of those lite blue are C your spare just happens to be BLUE could be any color,but r,g,y,w for the service guy walking up to it wax on wax off thing there!
Thermostat issues on old furnace - questions before I replace thermostat. Calab HVAC 11 02-18-2012 09:43 AM
Need help replacing an OLD General Controls Thermostat ohman HVAC 3 06-08-2011 06:35 PM
Replacing old Honeywell thermostat with new Honeywell thermostat optimizer HVAC 13 04-20-2011 07:22 PM
Need help connecting Trane TZEMT400 Thermostat; no 'C' wire / 24VAC dinki HVAC 1 04-04-2011 07:28 PM
Carrier Edge Thermostat Installation Issue ptalar HVAC 1 07-13-2010 06:40 PM
