24 Volt Transformer Fuse - HVAC - DIY Chatroom Home Improvement Forum
Old 11-20-2012, 06:22 AM   #1
Rewards Points: 150
24 volt transformer fuse
Im replacing my 24 volt transformer for my boiler it is a honeywell AT72D1683/U. There was no inline fuse on the 24 volt side outputs. I noticed on my dads boiler that he has a fuse to protect the tstat wiring in the house. What terminal on the transformer should have the fuse inline and what size fuse for 18 gauge tstat wire. There are three zone valves to supply 24 volts to. The aquastat takes care of the boilers gas valve 24 volts.
James Con is offline   Reply With Quote
Old 11-20-2012, 08:22 AM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 2,274
There should be a R terminal on the transformer. I commonly use a 3 or 5 amp plastic GM automotive fuses with spade terminals and use stakons to attach the wire to it and wrap it in electrical tape or you can buy a proper fuse holder at Radio Shack and use glass fuses.
Old 11-20-2012, 05:14 PM   #3
use this and you'll never replace a fuse again
hvac5646 is offline   Reply With Quote
208 volt delta transformer or 208V Y joe niemczyk Electrical 2 10-25-2012 06:47 PM
Fuse for chandelier with 12-volt transformer? S_Jeff Electrical 1 08-15-2012 11:19 PM
Low Voltage Transformer Problem dlp710 Electrical 2 07-06-2012 09:56 AM
goodman gmp 100-3 3 transformer fuse paulat120 HVAC 4 01-09-2012 09:09 PM
2 amp 250 volt fuse mjrdgez HVAC 1 01-07-2012 01:40 PM
