24 Volt Timer To Control Air Handler Fan - HVAC - DIY Chatroom Home Improvement Forum
Old 09-08-2010, 10:46 AM   #1
24 volt timer to control air handler fan
I have an open 3 story house w/ a wood stove on the main floor and want to distribute the warm air trapped in the upper vaulted ceiling via the return air duct thru the air handler while in the fan only mode. As my wood stove burn 24/7 6/7 mo. out of the year, I want to put a programmable timer on the "fan only" circuit of my thermostat/air handler. I want to be able to run the fan on a timed basis (10-15 min. per hr/ certain hours) and be able to shut it off w/ the "fan only" switch on the thermostat. Any ideas and/or help locating a supplier for a timer would be greatly appreciated.
hookit is offline   Reply With Quote
Old 09-08-2010, 01:49 PM   #2
Google either Honeywell or White Rodgers thermostats first.
You will have to go thru the specs of the stats to find what you want
You could Google the type of operation you want from a stat too.
You will find a PROGRAMMABLE FAN OPERATION feature in most high end stats.
You want to go on the cheap you could try Home Depot or Lowes.
hvaclover is offline   Reply With Quote
Tags
24volt timer , fan only , furnace fan
Help My Admiral Refrigerator is leaking water Cuwillis Appliances 10 03-25-2014 08:21 AM
12 Volt lighting AC or DC johnr9q Electrical 20 11-21-2010 01:12 PM
Wiring Tradeline L6006C Aquastat to Lennox CBWMV Hydronic Air Handler VIPSpecialNeeds HVAC 5 03-15-2010 06:37 PM
Timer to control two electrical devices worahm Electrical 5 01-28-2010 08:06 PM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 09:41 PM
