23 Year Old Rheem - HVAC - DIY Chatroom Home Improvement Forum
Closed Thread
Old 08-16-2009, 03:18 PM   #1
23 year old rheem
suggestions? opinions? the 23 year old outdoor rheem has a bad condenser fan motor. repair quoted at $500 - do I repair or replace?
live in nc -it's hot&humid, I would like a/c and would like to do the thing that makes cents/sense.
klrlettuce is offline
Old 08-16-2009, 03:23 PM   #2
GC/Master Plumber/Mech
Rewards Points: 560
I'd replace the system but if it was workng fine before the fan died and if money is tight then replace the fan motor.
With the system being 23yrs old it really is at the end of its life.
If you upgrade you could qualify for the tax credit.
If you feel OK with replacing the motor yourself it really isn't that hard to do and you can find one online for around $150. Just if you replace it yourself repace the capacitor too.
John Wayne once said "Life is tough and it is even tougher if you are stupid"
Tempstar and Trane Dealer
Plumber101 is offline
Old 08-16-2009, 04:22 PM   #3
HvacWiz's Avatar
Rewards Points: 252
500$ for a condensor fan motor replacement...WOW. Sounds like someone is making a big profit, call someone else.
HvacWiz is offline
Old 08-16-2009, 04:38 PM   #4
ok with replacing but feel overwhelmed with decision process - I will need to hire out any work done.
I agree I need to find another contractor (I got this one from a friend's recommendation). So do I just call a/c people in the book and ask them to do a load calculation?
Old 08-16-2009, 07:35 PM   #5
If you get enough bids, you can probably tell what you really need. To get 5 bids you may need to call 10 or 15 contractors.
.........a...bcd...e.........f
$0....1.....2.....3.....4.....5
........^relative price^
Bids a and f are probably outliers, and bcd seems to be the true price of doing your job in your zip code, today.
Incompetence and/or greed may cancel out to some extent with this method.
Grainger might have a replacement fan motor for $40. It needs to stand a 60 C ambient.
Has this unit been good so far?
HVAC lifetimes, courtesy of many knowledgeable posters
12 to 15 years for high end heat pumps,
7 to 10 years for builders grade heat pumps. Ocean front, 1 to 7 rears depending on brand and grade.
gas furnace 56 YO, HE (stainless) still in good shape,
AC is close to 35 YO, still the original compressor.
If you get 10 years out of air cooled equipment of any kind. You're doing well.
Midwest, we get 15-20 years out of a furnace and
20-30 out of an A/C,
20-50 out of a hot water boiler,
about 20 out of a cast iron steamer.
13 years HP,
15 to 18 for straight A/C,
18 to 20 gas and oil furnaces,
25 to 30 for gas and oil boilers.
Average is 12years for a heatpump, and
20for a straight A/C..
Yoyizit is offline
Old 08-17-2009, 04:46 AM   #6
An old Tradesmen
Rewards Points: 7,816
At 23 years old.
Replacing that fan motor is a gamble.
Often. The motor was spinning slow for sometime before it went out the whole way. And caused damage to the compressor.
Replacement can save you money in the long run.
beenthere is offline
Old 08-17-2009, 10:12 AM   #7
If the system ran good prior to the motor going bad then I'd replace it.
How do you know it's the motor and not it's capacitor??
It should be easy to replace but getting the fan blades off might be a PIA. Those fan blade hubs tend to corrode themselves onto motor shafts. If you get the blades off then take the motor to Grainger or Johnstone supply and they could match it up for you. I'd replace the capacitor at the same time.
It's a gamble. Your system could go on for another 10 years or die tomorrow. It's definately at the end of it's average life.
hennyh is offline
Old 08-20-2009, 02:36 PM   #8
From my earlier data samples only ~1/4th of HVAC equip has lived as long as yours and 3 out of these 25 died in less than 10 years.
10 out of 25 lasted more than 10 years and less than 20.
At the other end, 2 out of 25 lived 50 & 56 years.
The sample average life = 20 years.
yrs.|number
__________
<10|xxx
<20|xxxxxxxxxx
<30|xxxxxxx
<40|xxx
<50|
<60|xx
Yoyizit is offline
Old 08-20-2009, 05:24 PM   #9
Rewards Points: 1,668
I get 8.4 to 10.6 years on average depending how the calculation is done.
bob22 is offline
Old 08-20-2009, 07:59 PM   #10
We now have a thread in the Mod trash bin with over 40 posts from this bickering
If you don't have something of value to add then please do not start things
I've asked nicely 2x, won't be a third time unless its another Mod
Maybe its the heat but I'm not in the mood
Scuba_Dave is offline
Closed Thread
Looks like a good Christmas this year! leroyme Off Topic 6 12-23-2007 10:45 AM
Reroofing over Ten year old 3 tabbers gillaroo Roofing/Siding 15 05-01-2006 11:41 PM
