220 Volt Baseboard Heater With Low Voltage Thermostat - HVAC - DIY Chatroom Home Improvement Forum
Old 10-27-2011, 01:19 PM   #1
220 volt baseboard heater with low voltage thermostat
I have just re-installed my 24 inch baseboard heater with low voltage thermostat after doing a bathroom renovation. The heater is coming on and staying on and doesn't seem to respond to the thermostat. I believe I wired it up exactly like the one in the other bathroom. What is my problem?
melodan is offline   Reply With Quote
Old 10-27-2011, 04:59 PM   #2
An old Tradesmen
Rewards Points: 6,098
Usually, a baseboard heater uses a line voltage(220 volt) thermostat.
Old 10-27-2011, 05:06 PM   #3
biggles's Avatar
we know you didn't wire 220V thru a low voltage stat so there must be a transformer and relay for the stat to control one hot leg of that 220V or break both legs when the space satisfies..say yes please
Old 10-27-2011, 05:17 PM   #4
Thanks for the input. Yes, I have a relay/transformer. I had decided to use an identical one that my neighbor gave me when he switched to a forced air gas system. Unfortunately, the relay must have been shot because I just put the old one back in and I'm up and running again. Mind you, I sure wish the builder had put in line voltage thermostats when he built the house back in the late 80's... or perhaps that he had put in a forced air system!
Thanks again for your feedback.
Old 10-27-2011, 05:26 PM   #5
biggles's Avatar
except for the clicking sound your better off with that relay set up 24V stat reacts closer to the settings line stats are very raw control wise...
Pilot on Williams millivolt wall heater goes out every 8 to 16 hours wornways HVAC 30 06-22-2011 04:29 PM
Electric Baseboard Heater Is it O.k. to mount directly on Floor bltglt507 HVAC 4 12-05-2009 04:13 PM
Baseboard heater under window jhubert Electrical 1 10-07-2009 11:59 PM
What switch to install between panel and 220 volt heater Rogers Guitar Electrical 4 01-21-2009 07:08 PM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 10:41 PM
