20yr Old Keeprite Question - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 12-01-2012, 05:12 AM   #16
An old Tradesmen
Rewards Points: 7,356
As others have said, A/C coil needs checked. Its one of the things that often gets over looked as a cause of poor air flow during the heating season.
Old 12-01-2012, 10:20 AM   #17
Rewards Points: 77
Ok I would like to try and clean the 'A' coil but there is no access so where do I make the opening at the front of the plenum?
Thanks guys
mlijoi is offline   Reply With Quote
Old 12-01-2012, 11:37 AM   #18
I'm Your Huckleberry
Rewards Points: 2,270
Take a few pictures of the inside unit and post them.
Thanks.
Doc Holliday is offline   Reply With Quote
Old 12-01-2012, 12:35 PM   #19
Items wanted: Time
Rewards Points: 150
At best, if your lucky and careful, you'll be able to pull the Plenum apart, maybe by expanding a Pittsburgh joint. Slide the acoil off the furnace, should the lineset permit, on to some saw horses. This would give 100% access to clean the crap out of it.
NiNe O is offline   Reply With Quote
Old 12-13-2012, 08:35 AM   #20
Rewards Points: 77
I was finally able to take a few pictures of the unit and here they are. I took some tape off from around the a coil lines and drain and it seems there's more to just cutting a hole. There seems to be a plenum inside a plenum???
20yr old Keeprite question-2012-12-11-12.51.43.jpg   20yr old Keeprite question-2012-12-11-12.51.58.jpg   20yr old Keeprite question-2012-12-11-12.52.20.jpg   20yr old Keeprite question-2012-12-11-12.52.44.jpg
Old 12-13-2012, 10:22 AM   #21
Hvac Pro
yuri's Avatar
Rewards Points: 2,266
Having seen those pics I can safely tell you that furnace has obsolete burners,the exhaust fan is next to obsolete and VERY expensive if you can find one. If you can find those parts they now cost 2-3X what they used to retail for due to the rarity. Your choice whether to delay the ineveitable. Your AC coil is down against the top of the furnace and there is no access to the underside of it for cleaning. Even with a good filter properly maintained after 20 yrs dirt will still get into it and plug it up. If the AC is that age too it is on its last legs or can be. The AC coil can be cleaned when the furnace is removed for replacement. The freon level should be checked in the Spring. If it is low and the coil freezes and then leaks water into your brand new furnace then $1000 or more damage can occur.
Old 12-13-2012, 11:04 AM   #22
Roofmaster
Rewards Points: 2,210
Blower
First of all, I for one am constantly amazed at the level of knowledge that Yuri Posseses, Doc Too. Thanks to both of you.
Second of all, ATTEMPTED is not the same as cleaned, And if the evaporator coil has not been cleaned I completely agree with the poster that said the coil might be clogged with gunk.
If she pulled out the blower and the wheel and soaked and cleaned the vanes with a wire brush OK, then she cleaned it.
If that was all done then it is time for an upgrade to something more efficient.
My 2 cents. Not that it equals Yuri or docs 10 bucks.
Old 12-13-2012, 11:07 AM   #23
Roofmaster
Furnace
Thats a lot newer than my Dads, which we replaced about 20 years ago. His looked like a 40 Ford Sedan. Trim and All
Old 02-07-2014, 11:21 AM   #24
Rewards Points: 77
Does anyone know if this furnace has a flame sensor and if so where would it be?
Old 02-07-2014, 11:31 AM   #25
Hvac Pro
yuri's Avatar
The pilot burner does both spark and flame sensor off the one electrode.
The Following User Says Thank You to yuri For This Useful Post:
mlijoi (02-07-2014)
Old 02-07-2014, 01:27 PM   #26
Rewards Points: 77
Yuri thanks so much!
Is it good practice on these furnaces especially to routinely clean this electrode?
Old 02-07-2014, 05:09 PM   #27
Hvac Pro
yuri's Avatar
No. Unless you are a Pro and understand the grounding aspect and problems that can happen you should leave it alone.
DRIcore question trailblazer1229 Flooring 0 02-24-2010 09:25 AM
3 Phase meter socket question a320200 Electrical 4 12-11-2009 12:45 AM
An unasked question is the only dumb question jackie treehorn Kitchen & Bath Remodeling 1 09-20-2009 08:24 PM
A question about water preassure. reasonforseason Plumbing 5 04-14-2009 04:36 PM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 08:19 AM
