2010 Rheem RHLL-HM382IJA Air Handler Fan Not Working - HVAC - DIY Chatroom Home Improvement Forum
Old 09-21-2013, 08:28 AM   #1
Rewards Points: 459
2010 Rheem RHLL-HM382IJA air handler fan not working
I woke about a month 5 weeks ago to the sound of the air handler fan trying to start. The outside fan was working, turning on fan only also did not work but I could turn the air handler fan manually. I let it thaw out & installed a new Filtrete 1500 filter and within hours the unit was working again. It happened again several days ago. I woke to the sound of the air handler fan trying to start but this time after thawing out & installing new filter it's still not working several days later.
Any ideas?
Thanks!
2010 Rheem RHLL-HM382IJA air handler:
a1481155 is offline   Reply With Quote
Old 09-21-2013, 09:05 AM   #2
An old Tradesmen
Rewards Points: 7,370
First, if your going to use those 1500 filters. change them every 3 weeks.
Check to see if you have voltage(208/230-240) to the motor.
Old 09-21-2013, 09:13 AM   #3
Hvac Pro
yuri's Avatar
Rewards Points: 2,274
that unit has a X-13 constant torque motor which is tricky for some Pros and hard for a DIYer to troubleshoot. Try find a service manual (check the install or owners manual) for it online or get it from Rheem. It uses a low voltage signal from the circuit board to energize the motor. Has no capacitor and is not a PSC motor. You need a flow chart and some electrical experience and test meter and to follow the chart steps to check it, not easy to do over the net.
Old 09-21-2013, 11:47 AM   #4
Rewards Points: 459
Thanks!
Change filter every 3 wks...Got it!
I called original installers, they quoted a service call at $90 - $275 for labor depending on the location of unit (access is easy...in the garage) & the problem. But parts are still under warranty.
Old 09-21-2013, 04:28 PM   #5
An old Tradesmen
Let us know what they find.
Old 09-23-2013, 06:58 PM   #6
Rewards Points: 459
No capacitor...Confirmed. Motor is good but "module" attached to it needs to be replaced.
REPAIR ESTIMATE TOTAL = $225 (Parts: Under warranty + Labor: $225)
Old 10-29-2013, 04:58 PM   #7
Rewards Points: 459
UPDATE:
Actually, got this done for $180 or 2 hours labor. The service rep says this part goes bad all the time and don't last but maybe 3-4 years. Says they get a lot of calls for this especially during thunder & lightning storms. Don't recall the weather when this happened but they warranty the part for 10 years, you'd think they'd expect it to last close to that. Oh well, A/C fixed just in time to stop using it. ;p
Rheem LP Furnace not working bobweirisajedi HVAC 5 01-10-2013 01:26 PM
Is my new variable speed air handler working correctly? ink HVAC 3 11-26-2012 04:27 PM
rheem gas pack a/c not working poolhouse HVAC 7 08-14-2009 03:54 PM
Rheem 80 Plus Not Working techdesigner HVAC 3 10-20-2008 09:10 AM
Rheem furnace stopped working kgsolomon1 HVAC 1 02-09-2008 06:51 PM
