Old 11-27-2012, 06:43 PM   #1
20 year old slant fin boiler should I replace it
I own a 20 year old slant fin liberty boiler cast iron new hydrostat no leaks. 80 per cent efficient. Should I replace it. There is a lot of rust on the out side of the boiler.
Sheps58 is offline   Reply With Quote
Old 11-27-2012, 08:48 PM   #2
Super Moderator
Moved this to heating and cooling for you====Are you saying that the sheet metal case is rusty?
Have you had it serviced recently? If so what did the tech say? 20 years is not old for a boiler--although at that age some parts , like the pump and zone valves are nearing the end and may need changing===
Old 11-27-2012, 10:17 PM   #3
Missouri Bound's Avatar
My boiler was still running at 5o years old. But it needed a pump, expansion tank and was pretty inefficient....and way oversized.
Do you want it your way or the right way?
Old 11-28-2012, 05:26 AM   #4
An old Tradesmen
Rusted jacket look s ugly. But doesn't effect general operation.
Repair or Replace drjay9051 HVAC 7 05-12-2012 07:40 AM
Gaining efficiency with oil boiler Amazer98 HVAC 0 01-03-2012 08:27 AM
Boiler btu rjordan393 HVAC 2 12-12-2011 11:41 AM
pressure relief valve is leaking on boiler wlmpdiycr HVAC 65 10-26-2011 06:00 PM
12 year old HVAC unit, fix or replace Miranda7 HVAC 22 05-29-2009 08:44 PM
