20 Year Old Bryant 90i Does Not Produce Condensate - HVAC - DIY Chatroom Home Improvement Forum
Old 09-30-2011, 12:41 AM   #1
20 year old Bryant 90i does not produce condensate
My Bryant 90i still heats the house o-k, but I just discovered that for the last few days, there is no condensation water flowing to the sump pump well. I checked the tubing line from the furnace and it appears open. I have no other signs of water accumulating anywhere else.
Does this sound like a major failure of some components?
Any ideas if I should look at some component?
I'm going to call a HVAC service person soon.
Thanks for any help you can provide.
Rdiercks is offline   Reply With Quote
Old 09-30-2011, 01:01 AM   #2
JJboy's Avatar
http://www.bryant.com/products/gasfu...lution96.shtml
Check page 13 on the
  1. Condensing Gas Furnace Owner's Manual
**Always kill the power ** Hot air rises, but heat will always move from higher to lower temperatures. ** Real man shoot in manual. ** If it ain't grounded, it ain't dead.
JJboy is offline   Reply With Quote
The Following User Says Thank You to JJboy For This Useful Post:
Rdiercks (09-30-2011)
Old 09-30-2011, 01:31 AM   #3
REP
As a wild guess,I'd say check the secondary heat exchanger.If you have no condensate you are not getting a 90+% burn.
REP is offline   Reply With Quote
The Following User Says Thank You to REP For This Useful Post:
Old 10-01-2011, 12:30 AM   #4
I'm Your Huckleberry
Rewards Points: 2,270
How humid or rather how dry is it outside?
Doc Holliday is offline   Reply With Quote
Bryant Warranteed heat exchangers issues TruckTahoe HVAC 0 02-14-2011 03:21 PM
first time startup on Bryant furnace - furnace calls for heat and will not stop luvheat HVAC 22 02-14-2009 09:56 AM
Condensate and Humidity rosehillraymond HVAC 5 07-22-2008 09:21 PM
Burner on Bryant furnace won't come on Flylowflyslow HVAC 1 09-19-2007 01:57 PM
Reroofing over Ten year old 3 tabbers gillaroo Roofing/Siding 15 05-02-2006 12:41 AM
