20 Degree Difference From 1 Duct To Another - HVAC - DIY Chatroom Home Improvement Forum
Old 10-12-2010, 06:08 PM   #1
20 degree difference from 1 duct to another
Hello all, I have noticed that the air temp in one of my main trunk lines is 115f and the other is 135f I have tried manipulating registers but can not get it to balance out. I'm looking for any suggestions? It is a forced hot air furnace 113k BTU basement/upflow model about 1 year old. The hotter of the 2 ducts is on the side of the plenum and the cooler is on the front of the plenum (opposite the blower) both are 8" x 16" trunk lines and have offset takeoffs, although the takeoff on the hotter duct has a larger inlet apprx. 12"x16" as opposed to apprx 10" x 16" on the cooler duct (not sure if that matters but I figured I would give as much info as possible). Again any input would be greatly appreciated.
hawke1850 is offline   Reply With Quote
Old 10-13-2010, 04:00 AM   #2
sounds like you have a turbulence air issue or just a poorly designed plenum.
I have seen a lot of this in the field where two trunks coming off a common trunk.
hvaclover is offline   Reply With Quote
Old 10-13-2010, 04:13 AM   #3
An old Tradesmen
Rewards Points: 7,760
Take a pic and post it.
As above, could be turbulence.
Old 10-13-2010, 04:21 AM   #4
See, not bad for an NCI non grad.
Have yet to see common tapped plenums work well
Sealing air return duct jd1979 HVAC 8 10-07-2010 07:46 PM
Metal duct or flex? smokey982 HVAC 6 08-06-2010 06:20 AM
adding duct work and outlet jjrbus HVAC 17 05-30-2010 02:13 PM
Flex Duct Advice ssporty21228 HVAC 4 07-23-2008 08:28 PM
Condensation in Wall: Can I Seal a Dryer Duct With Caulk? xquercus HVAC 5 07-01-2007 02:33 PM
