2 Zones On Trane XE80 - HVAC - DIY Chatroom Home Improvement Forum
Old 02-18-2015, 08:59 AM   #1
Rewards Points: 60
2 zones on Trane XE80
Im planning to install a 2 zone setup for my basement and 1st floor.
I have 6 ducts opening to basement and 6 opening to 1st floor
do i need to buy 6 electronic dampers or 12 electronic dampers ?
trying to keep the costs low since these things are EXPENSIVE
Can you give me some guidance please.
thanks in advance.
xclaim is offline   Reply With Quote
Old 02-18-2015, 09:21 AM   #2
Rewards Points: 3,256
Zoning is normally done with the dampers in the main supply ducts.
zappa is offline   Reply With Quote
The Following User Says Thank You to zappa For This Useful Post:
xclaim (02-18-2015)
Old 02-18-2015, 11:35 AM   #3
Rewards Points: 60
thanks Zappa : so the 6 in the basement and the 6 in the 1st floor are supply ducts (not return) so do i just need 6 in basement or do i need 12 on all supply ducts ?
Old 02-18-2015, 12:20 PM   #4
I would think two unless you only have one supply trunk feeding both floors. I was thinking that you had two trunks but that might not be the case. Zoning can be complex and you have to consider bypass air when only one zone is flowing to keep the heat/ac equipment happy.
Tags
electronic dampers , zone
Trane XE80 No circuit board light twitch027 HVAC 3 02-05-2015 01:01 AM
Trane XE80 Furnace fan won't stop running Luv2Auction HVAC 2 01-07-2013 10:05 AM
Trane XE80 - No heat, No suprise ggutier49 HVAC 0 01-28-2011 09:44 AM
Trane xe80 no heat tackman HVAC 9 11-05-2010 02:33 PM
Trane XE80 Heating Question, Please help!!! Stephen1977 HVAC 3 01-30-2007 07:34 PM
