2-wire System Reversed? - HVAC - DIY Chatroom Home Improvement Forum
Old 02-24-2010, 10:35 AM   #1
Rewards Points: 518
2-wire system reversed?
Trying to replace a thermostat in my condo that uses a central boiler + hydronic baseboard heaters. I removed the old mercury thermostat that has two black wires. I've discovered that:
When the circuit is open = heat on
When the circuit is closed = heat off
I've tried two different digital thermostats and both cause the system to work in reverse. When I turn the heat up, the heat goes off, and vice versa. Is there anything I can do? I do not have access to the boiler room.
n0c7 is offline   Reply With Quote
Old 02-24-2010, 01:22 PM   #2
Rewards Points: 502
What type of thermostat are you putting in? make/model?
-Andrew
DIY hobbiest
AndrewF is offline   Reply With Quote
Old 02-24-2010, 01:39 PM   #3
Rewards Points: 518
Honeywell PRO 1000.
Manual - http://www.forwardthinking.honeywell...69_1968efs.pdf
Reverse valve jumper mentioned does nothing as its for a heat pump.
Old 02-24-2010, 03:03 PM   #4
An old Tradesmen
Rewards Points: 6,928
Wire it up as a cooling only thermostat. Set it to cool and what temp you want. It will work then.
Old 02-24-2010, 03:18 PM   #5
Rewards Points: 518
Hah! I guess that will work although it will confuse the hell out of people. hmm.
Old 02-24-2010, 03:21 PM   #6
An old Tradesmen
No worse then the old Coleman moble furnace units with A/C.
There was no heat or cooling switch on the stat. You turned a switch in the furnace to heat or cool. And the stat only had 2 wires.
Just leave a note inside the stat, that its connected to a reverse acting control system.
Old 02-24-2010, 03:31 PM   #7
Rewards Points: 518
Is this pretty common, and are there any adapters to reverse the control?
Old 02-24-2010, 03:42 PM   #8
An old Tradesmen
Not really common. But was done at large apartment buildings on occasion.
Your may have been a pnematic system at once. And the apartments converted to low voltage, but the boilers control system left as reverse acting.
There probably are some made. I just don't know of any off the top of my head.
Old 02-24-2010, 03:46 PM   #9
Rewards Points: 518
This would be by my manual thermostat has only R and Y terminals instead of R and W?
beware humidity system? Emaderton3 HVAC 5 02-10-2010 11:52 PM
Live ground wire in dryer Retired sailor Electrical 10 05-04-2009 03:26 PM
wire running question ponch37300 Electrical 4 04-21-2009 03:58 PM
Burial wire and a seeming difference of opinion... SxS Electrical 19 02-24-2009 09:16 AM
Size A/C system properly 70stang HVAC 1 03-26-2006 07:22 PM
