Im installing a bathroom in the basement. In the ceiling space, I have a duct supplying heat to the living room above. I was thinking, to get heat into the new bathroom, just cutting into the duct and adding a diffuser (or whatever you call them) to blow into the bathroom.
Obviously I can do this, but is it wise? Will adding a second vent mid-duct mean that all the hot air will exit the first vent (to the bathroom), and basically leave little for the second vent (going upstairs to the living room). OR will both rooms get about equal amounts of heated air?
If the new register (diffuser) for the bathroom is closer to the furnace than the existing registers, it could drain off a disproportionate share of the warm air from the duct. If you put in an adjustable louvered register, then you could balance the flow.
There are formulas for choosing the size (square inches) of a register cut right in the main duct versus a register at the end of a (lateral) smaller duct extending from the main duct. I don't know these formulas.
If you put a damper where you take off from the living room duct, you can adjust the airflow so that you still get adequate air to the living room and some to the bathroom. The advantage of the damper on the takeoff over an adjustable register is that it will be quieter and the air velocity will be lower.
The heat run for the living room was sized for that area only. It is not a good idea to change that. I would add another vent off of the main trunk line.
Yeah, I looked at that, but just the way the joists and existing duct work are, its not really possible without significant rearranging of stuff (more than it would be worth). There is another heat vent in the livingroom, and two in the dining room, which is open to the living room. Im not worried about some of the heat being diverted, just not all of it. But I suppose as the above poster mentioned, having an adjustable louvers would limit the air diversion. The bathroom itself I dont expect to be too cold anyways. The basement is well heated and insulated, and the bathroom is going to be pretty much in the middle. I could probably do without, but I thought it would be wise to have heated air going in on days that the shower is used, just to help circulate and remove any moist air and prevent any sort of dampness issues.
Other than the possible drifts of odor from the bathroom the livingroom via the ducting there is nothing wrong with the idea, especially if you add a means of balancing the two amounts of air. If you wanted to keep the volume to the living room you could increase the line size upstream of the new branch, say if it was 6" make it 7" and then add a reducer after the new duct tap.
Related Threads
DIY Home Improvement Forum
3.1M posts
319.6K members
Since 2003
