Old 09-16-2009, 11:43 PM   #1
2 tons???
The original unit for the upstairs in my home as built in 65 was 2 tons.
Is it safe for me to assume that I need to be shopping for a 2 ton replacement??
Service provider came out today & quoted for a 2 ton Trane XL16i.
nomad4137 is offline   Reply With Quote
Old 09-17-2009, 12:32 AM   #2
Moderator
Termite's Avatar
2 tons???
I started you a new thread as your post's original location was hijacking someone else's thread/question.
Old 09-17-2009, 02:03 AM   #3
2 tons???
Thanks!
So far I am thinking about American Standard Heritage20 model 4A7Z0024A1000B+
with the 4TEE3C03A1000A+ handler.
Good HVAC installer info for Dallas would also be appreciated.
Old 09-17-2009, 05:00 AM   #4
An old Tradesmen
2 tons???
If your old 2 ton was keeping the are cool and dehumidified, your probably safe with a new 2 ton.
Old 09-17-2009, 09:13 AM   #5
2 tons???
The official party line is to always do a load calc (aka Manual J) when sizing a unit. However, in your case you know how a 2 ton worked. As been said, if it cooled and dehumidified to your liking then that's about the right size.
Whatever you get quoted it could not hurt to verify that the indoor coil and outdoor unit will give you the same cooling BTUs as what you have.
dac122 is offline   Reply With Quote
Old 09-17-2009, 10:35 AM   #6
Moderator
Termite's Avatar
2 tons???
This is a DIY chatroom, not the place for contractor referrals.
Old 09-17-2009, 12:36 PM   #7
It was a dark and stormy
Yoyizit's Avatar
2 tons???
If the air felt clammy it was probably oversized.
For this many bucks get several bids and plot them on a line. A cluster of values is probably the true cost of doing this job in your ZIPcode today.
Old 09-17-2009, 12:44 PM   #8
2 tons???
Understood on referrals. This is well beyond a DIY project for me.
I am here mainly to try & make educated choices on equipment purchases.
Knowing what to look for in terms of an installer is also helpful!!
Old 09-17-2009, 06:03 PM   #9
2 tons???
American Standard Question concerning heat pump & furnace. If I want the AccuClean filter I need an air handler model 4TEE3D31??
How hard is it to add that same filtration to a 4TEE3C04?
Old 09-17-2009, 07:19 PM   #10
An old Tradesmen
2 tons???
Don't know.
Might be a Trane/American Standard contractor on here that can answer. If not, you'll have to call one.
Old 09-18-2009, 10:58 AM   #11
2 tons???
Am I likely to need a 3/4 line since this will be a 410 system?
The present system is on a 40 amp breaker, likely to big for the new unit.
Old 09-18-2009, 12:02 PM   #12
An old Tradesmen
2 tons???
Need to check th einstall manual.
R410A doesn't require as large of a line set as R22 on many installs.
Can just install the proper size breaker. No harm in having larger then needed wire.
Moving 9 tons of dirt...by shovel? Shpigford Landscaping & Lawn Care 19 06-17-2009 08:37 AM
Finishing the basement- tons of insulation questions QueenL Building & Construction 2 04-01-2008 02:25 PM
only 3 Tons for 3700 Sf Ft? 1K2GO HVAC 7 11-23-2007 07:13 PM
Very Newbie with tons of questions Aerovette Building & Construction 37 06-13-2007 11:04 PM
figuring what tons are needed pbuzz3323 HVAC 2 07-31-2006 07:40 PM
