2 T-stats - HVAC - DIY Chatroom Home Improvement Forum
Old 01-26-2013, 12:54 AM   #1
2 t-stats
I have a stupid question, can you run two t-stats on one hvac system? I have a two story house and we are having a problem keeping the far upstairs bedroom warm when I start a fire down stairs. I put a little fan on the steps trying to blow some heat upstairs but it is not enough to get to the back bedroom. I was thinking installing a t-stat base upstairs so I could move the t-stat up there when I have a fire down stairs. This should work right? Only one would work a time and the other one would just have open wires.
Thanks for the help.
subcool is offline   Reply With Quote
Old 01-26-2013, 02:08 AM   #2
Rewards Points: 13,296
http://www.perfect-home-hvac-design....ac-zoning.html
Old 01-26-2013, 05:56 AM   #3
I didn't want to spend the money for zoning. especially wwhen everything is perfect when I don't have a fire downstairs.
the two thermostat scenario would definitely be the cheapest way to go. the only problem I see is if I did have two thermostat at all times and not just two sub base is, if I accidentally had one in heat mode and one in cool mode, the reversing valve would get to signals. and I'm not even sure that's a problem because the reversing valve or (the orange wire) does not go to ground in heat mode I think it just opens, right?
Old 01-26-2013, 07:15 AM   #4
Rewards Points: 196
Get a wireless t stat so u can put in wherever you want.
HVACTECH96 is offline   Reply With Quote
The Following User Says Thank You to HVACTECH96 For This Useful Post:
hvactech126 (01-26-2013)
Old 01-28-2013, 02:47 PM   #5
Rewards Points: 77
Get a Honeywell red-link thermostat and a personal comfort control. The PCC can sense remotely.
Filtration / HVAC & Indoor Air Quality Solutions
AirstarFilters is offline   Reply With Quote
The Following User Says Thank You to AirstarFilters For This Useful Post:
hvactech126 (01-28-2013)
Old 01-28-2013, 03:11 PM   #6
Newbie Bill
Rewards Points: 520
I would think adding a T-stat upstairs would ensure a call for heat when that area gets cooler.
The only downside I see is you are going to be heating the area with the fireplace at the same time. Could get fairly warm down there before you reach the desired temperature upstairs.
Bill
A DIY Noob that knows just enough to be dangerous.
drtbk4ever is offline   Reply With Quote
Old 01-28-2013, 03:56 PM   #7
Missouri Bound's Avatar
Have you tried running the fan continuously? It will help circulate the heat, not sure if it will do enough for you.
Do you want it your way or the right way?
The Following User Says Thank You to Missouri Bound For This Useful Post:
Add thanked/thanks stats to user section of posts mikestorm5 Site Help and Suggestions 2 12-19-2012 08:08 PM
Looking for stats on “old” unit – Help jason24 HVAC 4 03-21-2012 10:08 AM
Noob Question about framing walls lmholmes11 Building & Construction 15 06-13-2010 10:58 PM
Would to see these failure stats on Kilz Primers and Behr dcheek20 Painting 7 01-25-2008 06:56 PM
Which Part to Replace? on my Hot Water Heater? ssammiewh Plumbing 6 06-15-2007 11:37 AM
