2 Story Up/down Thermostat Settings - HVAC - DIY Chatroom Home Improvement Forum
Old 06-08-2009, 09:52 PM   #1
2 Story up/down thermostat settings
I live in Georgia. I have no tree's, and all windows have blinds. Forced air with two seperate units/thermostats.....Can someone advise me on setting my temps during day/night and for up and down stairs?
The house is 3100 sq ft. down 2300 up 800 The center of the house is open 18' ceilings about 22' wide which are foyer, living room, and upstairs hallway. A bedroom on either side upstairs, all of the vents are in the bedrooms upstairs along with the thermostat. 3 returns one in hallway and each room. (should I leave doors shut?)
I set upstairs at 78 degress from 8-5P and downstairs 76. At 5P upstairs goes to 76 and downstairs to 74. At 9P i set upstairs to 75 and downstairs to 73. Master is on 1st floor
Is all this changing good or bad? Are my units struggling or is it saving some $ for the 8 hours during the day? Should I just leave at one temp.
When it's 95+ outside it takes 3 hours to catch up.
THanks
Ineedhelp2009 is offline   Reply With Quote
Old 06-16-2009, 06:35 PM   #2
anyone
Old 06-16-2009, 07:48 PM   #3
An old Tradesmen
Rewards Points: 7,746
Why are you setting your night time temp lower on the first floor. When you will be going to bed soon?
Around 6 or 7 (gives it time to cool the rooms and contents)set your upstairs to the temp you want it to be for sleeping. Don't worry about doing gradual temps.
Might want to set your downstairs stat up 2 when you go to bed.
Old 06-16-2009, 08:15 PM   #4
sorry did not say Master is on 1st floor. Son sleeps on second floor. My wife and I have to be cool when sleeping.
Old 06-16-2009, 08:29 PM   #5
An old Tradesmen
Ah, bad lay out.
Still, skip the intermediate settings. On hot days it may only shut off for a litle before your setting it lower.
Old 06-16-2009, 08:31 PM   #6
Ah, bad lay out.
whole house is layed weird. I found original plans prev owner changed alot of stuff
Yea today only 89 or 90 I got home at 7PM upstairs still 78 and down still 75 both were running nonstop since 5PM.
Old 06-16-2009, 08:34 PM   #7
An old Tradesmen
Make sure your air filters are clean.
Has you had them serviced recently.
Old 06-16-2009, 08:37 PM   #8
Have those the blue ones they say you can clean anygood? Just cleaned this weekend.
AC serviced no, but I believe I have a problem when heat comes on with the defroster not working on the outside unit... have not called someone out yet.... that happened last cold day of yr.
Old 06-16-2009, 08:38 PM   #9
someone told me a few years ago always keep second floor cooler because cold air drops?
The vents upstairs do not blow very hard at all!
Old 06-16-2009, 09:31 PM   #10
An old Tradesmen
I don't like cleanable ones.
Cool air will fall. but no real reason to keep second floor cooler.
Set it to the temp your comfortable at.
Coil may be getting dirty and restricting air flow.
Old 06-17-2009, 07:40 PM   #11
true. Man today left up on 76 HOLD it's still 77 degrees at 8:40PM
Old 06-17-2009, 07:45 PM   #12
An old Tradesmen
Low air flow can cause that.
Old 06-17-2009, 08:11 PM   #13
what would you suggest? clean coils? I checked temperatures coming out of the registers 58-61 degrees.
Old 06-17-2009, 08:20 PM   #14
An old Tradesmen
Clean both the indoor and outdoor coils.
Should have a tech check charge.
Old 06-18-2009, 06:53 PM   #15
Thanks for your help!
Thermostat VS Ceiling fan MrShadetree0222 HVAC 38 01-23-2010 03:29 AM
LSI thermostat stage settings trouble! weydoggy HVAC 1 11-27-2008 09:26 AM
How to optimize thermostat settings (2 heating systems same home) rossl56 HVAC 1 11-26-2008 03:39 AM
Wiring help - Honeywell Thermostat w/ Carrier Heat Pump Tom Williams HVAC 7 09-14-2008 07:40 AM
