2 Stage Water Source Heat Pump Systems. Real Savings Or Fluff - HVAC - DIY Chatroom Home Improvement Forum
Old 07-25-2011, 01:49 PM   #1
Rewards Points: 226
2 stage water source heat pump systems. Real savings or fluff
Totally excluding the cost of the system here, I would like to specifically ask about electric usage and efficiency of these systems in practice. I realize what the OEMS quote, 24-35 SEER ratings but I would really like to know if these are accurate and realizing that sometimes home efficiency is what it is.
Just FYI, I already have 4 wells and a 1acre pond so water source and disposal are not an issue.
Are these 2 stage systems typically operating with 2 compressors rather than a digitally controlled scroll?
Also, since it seems many systems are using an internal compressor and condenser coil, do these systems usually come precharged as a ready to use assembly or do they have to break down due to weight and size issues?
viper is offline   Reply With Quote
Old 06-14-2015, 03:53 PM   #2
Rewards Points: 7,224
Look for some extended performance data online.
COP will vary as the water temperature of the loop changes. Ideally should be sized so that you have to use minimal or no strip heat.
I'm no expert on geothermal - zero practical experience, never seen a system in my life, only on paper, but common sense dictates that heat exchanger fouling might be an issue with an open loop. Ask your contractor about water filtration.
user_12345a is online now   Reply With Quote
Old 06-14-2015, 07:32 PM   #3
An old Tradesmen
Rewards Points: 6,596
They are very very efficient. Most 2 stage use a 2 stage scroll.
Open loop, put a strainer in the inlet pipe.
Old 06-14-2015, 08:23 PM   #4
Rewards Points: 58
You can view live data of existing systems at welserver dot com. Many have watt meters in place and display operating costs. I look at WEL0063 sometimes because the house is similar to mine.
Stickman42 is offline   Reply With Quote
Hot water Heat repairs and our warranty Salvatorparadise General DIY Discussions 16 01-31-2011 12:35 AM
need help with natural gas vs air source heat pump decision supermaxhd HVAC 15 09-10-2010 06:27 PM
single stage and dual stage heat pump vshaynes HVAC 1 10-07-2008 10:18 PM
Water Mystery - Sump Pump Set Right? robertr4836 General DIY Discussions 4 02-13-2008 03:32 PM
water source heat pump mountaineer HVAC 1 08-02-2007 06:47 PM
