2 Stage Thermostat? - HVAC - DIY Chatroom Home Improvement Forum
Old 10-28-2010, 11:54 AM   #1
analogmusicman's Avatar
Rewards Points: 560
2 stage thermostat?
I just had a new Trane 2 stage furnace installed. will the 2 stages work with just my old 2 wire thermostat or do I need to run some more wires and buy a 2 stage thermostat?
tnx,
analogmusicman is offline   Reply With Quote
Old 10-28-2010, 03:57 PM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 396
It will work OK. The circuit board has a timed ON feature usually 7-10 min delay B4 it goes to high fire.
Old 10-28-2010, 07:24 PM   #3
An old Tradesmen
Rewards Points: 8,176
If you want the comfort you paid for though. Run the extra wires, and get a 2 stage thermostat.
Old 10-28-2010, 08:44 PM   #4
Hvac Pro
yuri's Avatar
Rewards Points: 396
Then you need to read the install manual and flip a dip switch on the board or move a jumper for it to recognize the 2 stage tstat. No big deal if you know where to look or how.
Old 10-28-2010, 08:50 PM   #5
An old Tradesmen
I did forget that detail.
but its a small thing, if you can wire up the stat yourself. You can flip the dip yourself.
2 stage thermostat with old wiring (4 wires)? bigbug HVAC 2 06-22-2010 12:34 PM
Configure an add-on radiator as stage 1 heat using a Honeywell thermostat hermhart7 HVAC 10 04-28-2010 05:39 PM
Multi stage heat pump thermostat marriedmanw HVAC 2 02-28-2010 04:12 PM
2 stage heating and thermostat settings BlueBSH HVAC 4 12-17-2009 08:07 AM
LSI thermostat stage settings trouble! weydoggy HVAC 1 11-27-2008 09:26 AM
