2 Stage Compressor - HVAC - DIY Chatroom Home Improvement Forum
Old 02-17-2011, 07:43 PM   #1
2 Stage Compressor
I have a Climate Master Tranquility 27 Geo Thermal system and not very happy with it's efficiency, so trying to understand everything possible about it. My local contractor says everything is fine, but I think I'm just getting normal lip service. In extreme temperatures the Entering Water temperature gets as low as 31 degrees, but of course contractor says everything this is normal. My question is, the unit in Stage 1 draws about 4.8kw and in Stage 2 draws about 6kw. The unit goes into Stage 2 15 mins after Stage 1 and does go into Stage 2 90% of the time. What is the purpose of Stage 1? Why wouldn't I want the unit to go full speed and get to set point sooner instead of running longer times while it is running is stage 1. Just a side note, we have had some extreme temperatures in Illinois the last couple of years and I have had the Aux Electric Breakers (80 amps worth) shut off, and the unit always seems to get to setpoint.
willijv is offline   Reply With Quote
Old 02-17-2011, 08:06 PM   #2
An old Tradesmen
Rewards Points: 6,140
Stage 1 allows for a more even heat distribution through out the house, and provides a better comfort, at a higher efficiency.
Is there a reason I shouldn't disable second stage heat? zootjeff HVAC 18 01-02-2011 03:23 PM
Air compressor and framing nailer for DIY ADKstorm Tools 20 11-11-2010 08:38 AM
Please help: blown fuse, slow compressor fan, and hissing noise from compressor frazwr01 HVAC 10 06-27-2010 10:08 PM
replacing 3 wire to 4 wire compressor fan - please advise! frazwr01 HVAC 2 06-27-2010 11:44 AM
New Compressor - Wrong Charge? shayneb HVAC 4 08-23-2008 09:13 AM
