2 Pipe Venting - HVAC - DIY Chatroom Home Improvement Forum
Old 10-18-2010, 01:03 AM   #1
2 pipe venting
I am installing a Carrier 58MEC060, gas fired furnace.
I want to vent THROUGH ROOF (11/2" x 12' schedule 40 pipe + 2 elbows) AND use combustion air ( 11/2" X 8' Schedule 40 pipe + 2 elbows THROUGH WALL. All installation instructions only show both pipes through roof or both through wall. Is it acceptable to vent through roof and pull combustion/makeup air through wall?
capybob is offline   Reply With Quote
Old 10-18-2010, 05:39 AM   #2
An old Tradesmen
Rewards Points: 6,086
No.
They need to be in the same pressure zones. If you have the intake thru the wall. The wind can cause the furnace not to run. Or not to be able to prove enough negative pressure in the heat exchanger.
Run the pipes in 2" thru the roof, and use a concentric termination/vent. Only 1 hole thru the roof then.
Old 10-18-2010, 07:29 AM   #3
Chicago, IL
Michael Thomas's Avatar
Beenthere is correct.
Some examples of how pressure differences in differing atmospheric pressure zones are created as wind moves over a structure:
- http://www.woodheat.org/chimneys/windbacksplit.gif
Here’s a diagram of how a concentric through-wall or roof vent is installed:
Typical installations instructions for a concentric through-wall or roof vent:
www.htproducts.com/literature/lp-166.pdf
Home Inspections, Infrared (Thermal Imaging) Leak Identification and Inspection Services, Roof, Attic, Building, Basement and Foundation Moisture Intrusion and Water Leak Inspections, Troubled Building Consultations - Serving Chicago and Suburbs http://paragoninspects.com/
Michael Thomas is offline   Reply With Quote
Frozen Vent Pipe Ratchye Plumbing 55 Yesterday 06:21 PM
How to stop sump pump discharge pipe freezing??? relbeig Plumbing 8 11-12-2012 01:03 PM
running black gas pipe lukeg Plumbing 6 10-25-2009 12:16 AM
PVC pipe broken on Gas Furnace/AC unit Keyo77 HVAC 8 10-16-2007 04:08 AM
Replacement pipe for hot water heat? Tmb9862 HVAC 18 01-12-2007 04:31 PM
