2 Inch Thick Ice On Heat Pump, - HVAC - DIY Chatroom Home Improvement Forum
Old 02-01-2011, 07:23 PM   #1
2 inch thick ice on heat pump,
is this a problem
Judy704 is offline   Reply With Quote
Old 02-01-2011, 07:26 PM   #2
Rewards Points: 392
Originally Posted by Judy704 View Post
is this a problem
Not if you've converted your heatpump to a ice maker.
That should never happen under normal use.
Your reversing valve may not be switching over for the defrost cycle.
zootjeff is offline   Reply With Quote
Old 02-01-2011, 09:46 PM   #3
Rewards Points: 6,652
is this a problem
Only if you are in the path that the Snowmageddon has been through.
Old 02-01-2011, 09:59 PM   #4
Mine was the defrost thermostat. I replaced the defrost card and thermostat for 65$ by doing it myself and getting my parts from Ebay. After taking out the thermostat and testing it I found that it was stuck OPEN. Therefore it never called for the board to defrost the unit.
Turn your unit to A/C ON. Set the thermostat about 2-3 degrees lower than the inside temp. You should see the ice slowly begin to melt off of the condensing coils. If it does, then your reversing valve is good. Continue to do this to keep your outside unit thawed out(maybe 2-3 times a day if needed) until you can get a tech. out and have look or fix it yourself.
Hope this helps.
Have a look at my thread.
replacement for bryant cess410104 defrost board
aalan is offline   Reply With Quote
Old 02-03-2011, 09:47 PM   #5
I would love to know if you have resolved your problem, and if so what exactly fixed it. That is how we all learn.
Heatpump vs Natural Gas - Energy Cost Spreadsheet zootjeff HVAC 11 06-22-2015 04:59 AM
Heat pump ice up signpainter HVAC 9 01-02-2012 10:44 AM
Trane Heat pump capacitor exploded! swiffy25 HVAC 18 01-19-2011 06:48 AM
Using Gas heat during Defrost mgroves HVAC 15 12-18-2010 06:51 PM
Comparison and Heat Pump Selection help... ChrisDIY HVAC 7 03-06-2010 09:34 PM
