#2 Heating Oil Alternatives - HVAC - DIY Chatroom Home Improvement Forum
Old 01-10-2010, 06:10 PM   #1
Rewards Points: 91
#2 heating oil alternatives
I ran out and suppliers were out too. One told me to use diesel and I did some research and tried it and it worked ok. What's the long term consequences if I keep using it? Someone else said i can use #2 kerosene. Can I? Researching I found out that #1 kero is same as #1 heating oil. My burner can use #1 or #2 heating oil. Whats the story with #2 kero? I also found out that diesel comes in #1 and #2, but I dont know which is which.
1-I want to be sure of what I can use as backup.
2-I want to look into alternatives, if they are cheaper. Diesel at the pump is cheaper then #2 heating oil delivered. Is pump #1 or #2 and does it matter to me?
3-A friend has 25 gallons of old #2 kero he said I can have.
beckett model AFG burner in a bryant system.
tks much, P
paulmars is offline   Reply With Quote
Old 01-10-2010, 06:23 PM   #2
For heat value alone, assuming 100% efficiency, they are all within +/- 2% of each other.
Old 01-10-2010, 08:00 PM   #3
An old Tradesmen
Rewards Points: 6,480
#1 kerosene and fuel oil are the same.
#2 kerosene and fuel oil are the same.
Kerosene is a trademark name(like freon). That has become a common term for #1 fuel oil.
Old 01-10-2010, 08:19 PM   #4
Master General ReEngineer
Bondo's Avatar
Rewards Points: 602
Ayuh,... You can safely burn All of them....
#1 oil,..
#2 oil,...
Diesel is the same oil, just taxed differently...
Old 01-10-2010, 10:26 PM   #5
Rewards Points: 91
fuel oil? gasoline and wax are fuel oils, right? Am I missing something? Any oil, that is a fuel, is a fuel oil. Whale oil is a fuel oil.
Old 01-10-2010, 10:48 PM   #6
Hvac Pro
yuri's Avatar
Rewards Points: 1,412
But there is never a whale around when you need one.
Old 01-10-2010, 11:08 PM   #7
An old Tradesmen
LOL...
Ok.
#1 Kerosene and #1 fuel oil are the same thing.
#2 Kerosene and #2 fuel oil are the same thing.
Gasoline is NOT an oil. It is a distillate from oil, with additives.
Old 01-11-2010, 07:26 AM   #8
:thumb sup:
SULTINI is offline   Reply With Quote
Old 01-11-2010, 06:43 PM   #9
Rewards Points: 91
how can I test old kerosene to see if its still good and how can i be sure its kero?
Old 01-11-2010, 06:47 PM   #10
An old Tradesmen
Lab test.
How old is old.
Old 01-11-2010, 06:51 PM   #11
Household Handyman
Rewards Points: 1,408
"But there is never a whale around when you need one" by "Yuri". Errrr---Yuri, have you met my first wife?
Old 01-11-2010, 06:53 PM   #12
Licensed Engineer
Rewards Points: 171
I always thought.......
That #1 Fuel Oil = Kerosene = Jet Fuel,
and that #2 Fuel Oil = Diesel (without any engine additives)
MI-Roger is offline   Reply With Quote
Old 01-11-2010, 06:53 PM   #13
An old Tradesmen
She's yuri's long lost sister.
Old 01-11-2010, 07:00 PM   #14
An old Tradesmen
Diesel. Is the name of the inventer of the engine.
So they named the fuel after him.
Diesel fuel does have additives in it.
Jet fuels are kerosene based.
Old 01-11-2010, 07:45 PM   #15
Hvac Pro
yuri's Avatar
Her name is Olga, good Russian gal. BTW they had to double the price of Vodka in the old country. Seems like we have a drinkin problem and makin it more expensive is supposed to stop that.
Mini Split for heating in cold climate landev HVAC 9 01-29-2012 11:18 AM
Hydrokientix Heating System Not Heating damonl73 HVAC 11 12-18-2009 06:12 PM
Electrical consumption of baseboard heater CowboyAndy Electrical 7 03-24-2008 08:27 PM
Trane XE80 Heating Question, Please help!!! Stephen1977 HVAC 3 01-30-2007 07:34 PM
