2 Furnaces And Water Heaters - HVAC - DIY Chatroom Home Improvement Forum
Old 02-12-2009, 09:52 AM   #1
2 furnaces and water heaters
I am fixing to buy the house I've been renting. It has an addition which is hooked up to a furnace and water heater in the basement. For the older part of the house it is in the laundry room on the main level. The vents for addition are on the floor. Vents for other half are on the ceiling. Is there any way I could hook everything up to just the ones in the basement?
hquinn3 is offline   Reply With Quote
Old 02-12-2009, 12:54 PM   #2
You gonna have to clarify what you mean. Don't know if you mean ducts or chimney flues for the furnace and water heater.
hvaclover is offline   Reply With Quote
Old 02-14-2009, 09:59 AM   #3
2 furnaces
I have 2 furnaces. 1 is on main level w/ the vents coming out of the ceiling. the 2nd is in the basement and the vents in that part of the house is on the floor. I only want 1 furnace. I also have 2 water heaters. only want 1 of each. should i just get a quote from a specialist?
Old 02-14-2009, 10:11 AM   #4
An old Tradesmen
Rewards Points: 7,742
You might want to get a quote.
If you do switch to just one furnace, and one water heater.
You will probably not like, either the price to do it, or the way it works afterwards. Or both.
Old 02-14-2009, 10:31 AM   #5
How big is the house?
Is it a one family or tow family?
How big are the water heaters? Gas, electric or?
Old 02-14-2009, 12:41 PM   #6
gas w/ electric start
the furnaces are both gas w/ electric start. water heaters are gas also i think. and it's a single family home. 1600 sq. ft.
Old 02-14-2009, 01:35 PM   #7
An old Tradesmen
Unless one of them is oversized.
You'll have to buy a new furnace.
When you already have 2 working ones.
Do you want to do this to save on the heating bill?
It probably won't save you anything.
And may cost you more to heat the house.
Old 02-14-2009, 03:39 PM   #8
Our old WH was a 30g - enough for 2 people
You need to do a heat loss calc to determine the size furnace needed to heat your house. Without that everyone is just guessing if one will meet the needs of the house
Our house is from the 50's, boiler is 22 years old & oversized - 1640 sq ft house. My heat loss I needed ~70k btu = so with a 86% efficient oil boiler I needed about 81k btu
My boiler is actually much large then that
Check them & see what they are rated for
Old 02-14-2009, 05:57 PM   #9
Rewards Points: 150
Mmm.. I think he has forced air.
Gary
Gary_602z is offline   Reply With Quote
Old 02-14-2009, 08:43 PM   #10
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,596
Yes,...
Bondo is online now   Reply With Quote
Old 02-15-2009, 01:37 PM   #11
get a quote than when said quote is the price of a nice 5 or 6 year old used car, move on to the next project. ( In other words, its probably not going to be worth it)
kennzz05 is offline   Reply With Quote
Old 02-15-2009, 02:08 PM   #12
Yes, of course running 2 furnaces & 2 WH will be less expensive long term
Old 02-15-2009, 04:35 PM   #13
Bondo's Avatar
Well,...
It would be Cheaper to run it as it is, until any of the units Quit,...
Then it's gonna be a 'ell of a plumbing tab to change anything,...
The DHW is 1 thing,...
But 2 hot air furnaces probably won't support the loss of each other...
Hot air is alot tougher to move along ways,....Ducting takes Alota space,.. etc...
How to diagnose gas valve problems Nestor_Kelebay How To Guides 28 10-30-2013 04:19 PM
Resource for understanding gas valve? darsunt HVAC 19 02-03-2009 11:08 PM
Heat Pump vs Aux Electric Heat batolson HVAC 16 01-17-2009 10:28 AM
Water leaking from Heil gas condensing furnace BlueStar HVAC 5 11-23-2008 05:47 AM
Water in Furnace Ducting sdoca HVAC 3 09-14-2007 06:54 AM
