Old 02-12-2011, 08:37 AM   #1
2 furnaces off one oil tank
Hi,
I have an oil based heating system, and live in a duplex, so there are 2 furnaces and 2 oil tanks. I plan on converting my heating system to an electric one sometime this summer. Now, one of the oil tanks is running low, while the other is full. Once the one running low has run out, could I make a "Y" from the full oil tank and feed both furnaces? Would this work? It wouldn't be used for long as theres less than 2 months left of the cold season.
sbmfj is offline   Reply With Quote
Old 02-12-2011, 11:24 AM   #2
Master General ReEngineer
Bondo's Avatar
Originally Posted by sbmfj View Post
Hi,
Ayuh,... Depending on how it's plumbed, Yes, anything is possible...
Old 02-12-2011, 11:57 AM   #3
Experienced
Jackofall1's Avatar
Yes but to do it correctly you must determine what your max flow rate is and the size the main line accordingly, then you will have to purchase the appropriate Y so as not to starve either unit.
Mark
Old 02-12-2011, 03:52 PM   #4
An old Tradesmen
Who owns the oil in the other oil tank?
Are you getting a heat pump installed instead of your oil furnace?
Old 02-12-2011, 09:18 PM   #5
I own the other oil, ie the full tank. Im going electric. Im in Quebec, electricity is very affordable.
Low hot water pressure crebive Plumbing 38 02-26-2013 01:26 AM
Oil furnace / tank questions... pure_energy1 HVAC 26 06-22-2009 09:47 PM
Toilet jpark Plumbing 18 01-05-2009 08:12 AM
Nightmare water tank job Marvin Gardens Plumbing 6 11-04-2008 12:09 PM
Upstairs toilet pipe noise bliss Plumbing 8 01-10-2008 08:55 AM
