2 Filters? 20x25x4 + 20x25x1 - HVAC - DIY Chatroom Home Improvement Forum
Old 06-10-2012, 05:05 PM   #1
2 filters? 20x25x4 + 20x25x1
My furnace requires a 20x25x5 filter, however had someone out to clean it and they charged me for a 20x25x5 but used a 20x25x4!
I called to complain and they dropped off a 20x25x1 filter to "double up" an said this is just fine. I cant really read anything online if this will work but seems to be more cost effective as the 4 inch filter is to be replaced each year while the 1 inch is every three month, but the 1inch is $14 online compared to $70 for the larger one.
Think this will be ok to do? Otherwise I have to have them come out and their 5inch filter is $26 more and don't really want to pay and wait two weeks.
HVAC_PA is offline   Reply With Quote
Old 06-10-2012, 05:33 PM   #2
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 46
The very thick ones usually have different stages, so you're probably fine. For the 1 inch you can probably get away with a cheapy one to capture the bigger stuff. Though if you get a slightly more expensive one it should make the 4 inch one last longer provided you place it first. That's what I would do. See what the hvac pros say though...
Old 06-10-2012, 06:50 PM   #3
AKA HVACTECHFW
Rewards Points: 1,208
Those are nominal dimensions and there is no REAL difference between a 4" and 5" filter. You should not use 2 filters especially if the 1" is pleated. A fiberglass 1" would be fine though.
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Old 06-10-2012, 08:33 PM   #4
For that kind of money you should maybe get a plastic manometer and use it to tell when the filter needs replacing rather than following a one-size-fits-all schedule.
Old 06-10-2012, 10:44 PM   #5
Pull the one inch out and just use the 4". Two filters can really mess with air flow.
Furnace filters/ AC filters? Alisalm HVAC 4 02-27-2012 04:37 AM
Cut to Fit fiberglass filters GEAF HVAC 1 03-24-2011 01:49 PM
Al. mesh filters lottaair HVAC 1 09-13-2010 06:34 PM
Furnace Filters rjordan392 HVAC 39 04-13-2009 12:40 PM
My HVAC repairman recommends cheap filters? scarl HVAC 9 08-16-2008 07:09 PM
