-   -   2 filters? 20x25x4 + 20x25x1 (http://www.diychatroom.com/f17/2-filters-20x25x4-20x25x1-146639/)
HVAC_PA 06-10-2012 05:05 PM
My furnace requires a 20x25x5 filter, however had someone out to clean it and they charged me for a 20x25x5 but used a 20x25x4!
I called to complain and they dropped off a 20x25x1 filter to "double up" an said this is just fine. I cant really read anything online if this will work but seems to be more cost effective as the 4 inch filter is to be replaced each year while the 1 inch is every three month, but the 1inch is $14 online compared to $70 for the larger one.
Think this will be ok to do? Otherwise I have to have them come out and their 5inch filter is $26 more and don't really want to pay and wait two weeks.
Red Squirrel 06-10-2012 05:33 PM
The very thick ones usually have different stages, so you're probably fine. For the 1 inch you can probably get away with a cheapy one to capture the bigger stuff. Though if you get a slightly more expensive one it should make the 4 inch one last longer provided you place it first. That's what I would do. See what the hvac pros say though...
hvactech126 06-10-2012 06:50 PM
Those are nominal dimensions and there is no REAL difference between a 4" and 5" filter. You should not use 2 filters especially if the 1" is pleated. A fiberglass 1" would be fine though.
Yoyizit 06-10-2012 08:33 PM
For that kind of money you should maybe get a plastic manometer and use it to tell when the filter needs replacing rather than following a one-size-fits-all schedule.
Marty S. 06-10-2012 10:44 PM
Pull the one inch out and just use the 4". Two filters can really mess with air flow.
