2 Clothes Dryers Exhaust Vent - HVAC - DIY Chatroom Home Improvement Forum
Old 11-26-2010, 04:40 PM   #1
2 clothes dryers exhaust vent
I have 2 dryers, each with its own exhaust exit. Can I take each 4in exhaust pipe and T-split into a 6in exhaust and exit the house with a 6in exhaust. Each 4 in pipe will have its own dryer back draft unit.
icandoanything is offline   Reply With Quote
Old 11-26-2010, 04:50 PM   #2
GC/Master Plumber/Mech
Rewards Points: 560
Depending on your local code it may or may not be Ok.
But I have done this. Use a "Y" instead of a "T"
John Wayne once said "Life is tough and it is even tougher if you are stupid"
Tempstar and Trane Dealer
Old 11-26-2010, 07:59 PM   #3
Registered User
Rewards Points: 5,216
Nope.
M1502.2 Independent exhaust systems. Dryer exhaust systems shall be independent of all other systems and shall convey the moisture to the outdoors.
Exception:
This section shall not apply to listed and labeled condensing (ductless) clothes dryers.
From: http://publicecodes.citation.com/ico...002_par001.htm
Gary
Old 11-27-2010, 06:47 AM   #4
AKA HVACTECHFW
Rewards Points: 1,208
no, there is nothing keeping the dryer you are not using from allowing CO to come back into it and then into house
hvactech126 is offline   Reply With Quote
Old 11-28-2010, 03:21 PM   #5
Rewards Points: 81
Also bad with electric dryers . This may wind up shorting the life of both dyers ( Fabric softener, lint, moisture contamination). Install back draft dampener or separate vents. Depending on the run a dryer vent booster fan may also be needed .
rkpatt is offline   Reply With Quote
Tags
2 dryers - 1 exit , dryer venting
Gas furnace exhaust vent question nowell HVAC 7 01-30-2012 09:31 AM
Gas HW Heater exhaust vent caulk jbaker1516 HVAC 2 06-17-2009 04:39 PM
extending my direct vent exhaust tube brianbh HVAC 5 02-13-2008 04:25 PM
Can I T my new dryer's exhaust into my bathrooms exhaust? Felipon Appliances 2 01-30-2008 07:53 PM
