-   -   2 clothes dryers exhaust vent (http://www.diychatroom.com/f17/2-clothes-dryers-exhaust-vent-87799/)
icandoanything 11-26-2010 03:40 PM
I have 2 dryers, each with its own exhaust exit. Can I take each 4in exhaust pipe and T-split into a 6in exhaust and exit the house with a 6in exhaust. Each 4 in pipe will have its own dryer back draft unit.
Plumber101 11-26-2010 03:50 PM
Depending on your local code it may or may not be Ok.
But I have done this. Use a "Y" instead of a "T"
Gary in WA 11-26-2010 06:59 PM
Nope.
M1502.2 Independent exhaust systems. Dryer exhaust systems shall be independent of all other systems and shall convey the moisture to the outdoors.
Exception:
This section shall not apply to listed and labeled condensing (ductless) clothes dryers.
From: http://publicecodes.citation.com/ico...002_par001.htm
Gary
hvactech126 11-27-2010 05:47 AM
no, there is nothing keeping the dryer you are not using from allowing CO to come back into it and then into house
rkpatt 11-28-2010 02:21 PM
Also bad with electric dryers . This may wind up shorting the life of both dyers ( Fabric softener, lint, moisture contamination). Install back draft dampener or separate vents. Depending on the run a dryer vent booster fan may also be needed .
