2.5 Ton Trane XL 1200 Ain't Keep'en Up With The Cold - HVAC - DIY Chatroom Home Improvement Forum
Old 01-09-2011, 10:59 AM   #1
2.5 ton Trane XL 1200 ain't keep'en up with the cold
My unit is a Trane XL 1200 gas pack and when the temps get down in the low 20's this unit just has a heck of a time keeping the house warm (66 degrees is the setting and it was 63 in here when I got up this morning). The air from the register's is noticeably cooler when it gets this cold. The house is about 1700 sq ft. heated space. I do know that I have a "spider" duct system that is probably a major part of the problem. I have been in the crawlspace and checked to make sure none of the connections have come undone.I don't know if the heat exchanger is on it's last leg or not because I haven't had a look at it recently. But I wanted to see if you guy's could tell me anything else to look for. BTW, I have recently changed the filter.
DIY DUDE is offline   Reply With Quote
Old 01-09-2011, 11:49 AM   #2
AKA HVACTECHFW
Rewards Points: 1,208
check for codes on control board when system not keeping up
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Old 01-09-2011, 11:57 AM   #3
Will do. I've replaced that board twice too
Will do. I have replaced that board twice too, LOL. No more trouble with it in the last few years though
I'll set the T-stat for a call for heat and see if any codes pop up. Of course now the outside temp is up to 34, so I doubt there will be any codes.
One other thing I have noticed when the unit won't keep up, is that the you hardly see any smoke from the exhaust fan of the unit. Does it make sense that it just gets so cold that the natural gas isn't spreading out on the HE to produce enough heat?
Old 01-09-2011, 12:16 PM   #4
Just went out while it was calling for heat and had a look at the board. According to the info that I have for this board it is operating as normal (lid green). That said, I could lay my hand down on top of the inducer motor fan exhaust and it was luke warm. Shouldn't that thing be pretty hot?
Old 01-09-2011, 12:31 PM   #5
AKA HVACTECHFW
it depends... with unit calling for heat and it has stopped producing heat then check the board. have you done that? check for air leaks where your ducts hook up as well.
IT IS WHAT IT IS
Old 01-09-2011, 12:55 PM   #6
It's heating like it normally would now that the outside temperature is above 30 degrees. But when it's colder than that it just can't keep up. No bad connections in the duct system. I'll have to check the board tonight after the temp drops to see if it is producing any codes.
Old 01-09-2011, 01:03 PM   #7
AKA HVACTECHFW
is the gas pack a h/p with gas backup or is your only heating source gas
IT IS WHAT IT IS
Old 01-09-2011, 01:04 PM   #8
All NG.
Old 01-09-2011, 01:55 PM   #9
An old Tradesmen
Rewards Points: 6,886
Could be low gas pressure. Something restricting the manifold.
Old 01-09-2011, 02:41 PM   #10
There could be a restriction in there somewhere. I'm just wondering why it the trouble always starts when the outside temp gets into the low 20's or colder. Seems like if there was a restriction it would happen a majority of the time. I was just out there and I couldn't put my hand near the exhaust because it was hot.
Old 01-09-2011, 04:49 PM   #11
An old Tradesmen
Restriction to gas flow, wouldn't show up as much at warmer temps. Since just enough gas could be flowing to heat the house.
Old 01-09-2011, 05:15 PM   #12
Rewards Points: 161
My Trane XL1200 was a heat pump. I believe you have the equipment model incorrect.
kb3ca is offline   Reply With Quote
Old 01-09-2011, 07:17 PM   #13
The number is correct and mine is a gas pack. I've worked on it enough times to easily remember that number, LOL!
Actually Trane built a gas pack, gas/electric and heat pump with the same model number.
Old 01-15-2011, 01:05 PM   #14
After a week of the unit keeping the house at 66 degrees as set on the TS, this morning the temp inside dropped to 64. Today's outside temp was 45 degrees when I went out to try and do some trouble shooting. Again, I could put my hand over this inducer exhaust fan and it was luke warm. So I took the panels off and check the board. All was showing normal there, I then tapped on the regulator to see if there was a blockage or whatever. Unit continued to run luke warm, so I then flipped the breaker to reset the system. When I started it back everything sounded normal (inducer fan buzz from ig-nighter then the whoosh from the HE lighting. While it was running as "normal" I noticed that it would sound as if it was relighting in the HE chamber (no buzz from the ig-nighter when this was happening) this happened a few times and didn't happen again. The inducer exhaust got real hot, too hot to touch and has been running normally so far. Does this still sound like a regulator issue or does it sound like the HE is on it's last leg.
Oh yeah almost forgot, I was getting a bad odor in the house where the gas wasn't completely being burned off.
Old 01-15-2011, 01:55 PM   #15
AKA HVACTECHFW
good possibility of bad HE
IT IS WHAT IT IS
Trane XR 80 furnace blowing cold air as117 HVAC 1 11-28-2010 10:53 PM
Trane EX80 - Blowing Cold Air Thome HVAC 2 10-29-2009 09:57 PM
Trane XE80 Gas Furnace only blowing cold air pamelascott HVAC 0 10-15-2009 04:25 PM
Trane Heat Pump Not Blowing Cold JbIcon HVAC 3 09-01-2009 10:15 AM
Trane xe 1200 Reverse solenoid valve rick208 HVAC 3 07-14-2009 02:06 PM
