1995 Luxaire Furnace Issue - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 11-09-2012, 07:43 AM   #16
weinstall.ca
Smile
Furnace repair Toronto
Just did a furnace repair in Toronto to the same type of furnace, it was the pressure switch
. Make sure the drain is clear and the tubing isnt cracked from the pressure switch.
Originally Posted by neastguy View Post
currently the furnace will keep the house up to temperature for a good 8 hrs.. but then I have to go down in the basement and turn the power off to the furnace and then it kicks back on and works again for another 1/2 day.. I had a tech come out, but when he came the furnace actually decided to work.. I think if it sits for a long time when it doesn't want to work and you bump up the heat .. it will kick on.. anyhow, he recommended that I switch out the thermostat.. although he thinks it may be the circuit board being bad.. for the life of me, I kind find where to look to find the flashes on the unit.. can anyone explain to me where it I should look in the unit? also, do you think I'm wasting my time on replacing the thermostat? thanks.......
below is what my furnace looks like on the inside.. cant find where its supposed to flash
allan is offline   Reply With Quote
How to change blower speed in Luxaire furnace joef2 HVAC 2 11-25-2015 07:09 PM
Ruud Furnace issue grubslinger HVAC 16 09-14-2011 12:13 AM
Luxaire Furnace problem Orlo HVAC 32 01-03-2011 12:18 PM
Luxaire Furnace Won't Fire ChuckAnderson HVAC 14 12-07-2010 09:19 PM
Luxaire Furnace mobear HVAC 1 03-13-2005 11:54 AM
