1995 Luxaire Furnace Issue - HVAC - DIY Chatroom Home Improvement Forum
Old 03-05-2012, 07:01 AM   #1
1995 luxaire furnace issue
currently the furnace will keep the house up to temperature for a good 8 hrs.. but then I have to go down in the basement and turn the power off to the furnace and then it kicks back on and works again for another 1/2 day.. I had a tech come out, but when he came the furnace actually decided to work.. I think if it sits for a long time when it doesn't want to work and you bump up the heat .. it will kick on.. anyhow, he recommended that I switch out the thermostat.. although he thinks it may be the circuit board being bad.. for the life of me, I kind find where to look to find the flashes on the unit.. can anyone explain to me where it I should look in the unit? also, do you think I'm wasting my time on replacing the thermostat? thanks.......
below is what my furnace looks like on the inside.. cant find where its supposed to flash
neastguy is offline   Reply With Quote
Old 03-05-2012, 10:06 AM   #2
how
Rewards Points: 1,104
If your furnace has a flashing led light it will be on the board in the fan compartment below. There is usually a viewing port in that door but you may have to move your head around to see the led light. Some times it is nesseasary to tape in the blower door switch so that you can remove the door after the next lockout to observe the diagnostic code without cutting off the power to it.
how is offline   Reply With Quote
Old 11-02-2012, 07:55 PM   #3
Rewards Points: 31
luxaire
my light flashes 3 times in a row can you tell me whats wrong
upnorthdennis is offline   Reply With Quote
Old 11-02-2012, 08:03 PM   #4
how
You will have a legend inside your furnace that will tell you. Its usually glued to the inside of one of the furnace doors.
Let us know what it is.
Old 11-02-2012, 08:25 PM   #5
Rewards Points: 31
legend
ion doors there is a wiring diagram nothing that says anything about flashes
Old 11-02-2012, 08:27 PM   #6
Rewards Points: 31
i am thinking my furnace is 98 ish
Old 11-02-2012, 08:33 PM   #7
Rewards Points: 31
legend
ok on wiring diagram it says legend
but it does not say how to respond to flashes it says like P1/S1 or P2/S2
Old 11-02-2012, 08:46 PM   #8
how
Usually there is a list on the inside of the furnace doors or on the board where the flashing led is.
Old 11-02-2012, 09:04 PM   #9
Rewards Points: 196
Neastguy ,try cleaning flame sensor.It is hard to remove because of the way it is mounted from side.I usually remove far left burner and clean sensor with emery cloth.Be carefull you dont pull on sensor while cleaning and break it.The led on that unit is under burner unless it has upgraded whiterodgers circuit board.
HVACTECH96 is offline   Reply With Quote
Old 11-02-2012, 09:06 PM   #10
Rewards Points: 196
Picture is alittle fuzzy,couldnt tell if sensor is mounted on top or thru side?
Old 11-08-2012, 07:28 PM   #11
Rewards Points: 31
luxaire furnace what and where is a pressure switch it has 3 flashes says pressure switch stuck open
Old 11-08-2012, 07:29 PM   #12
Rewards Points: 31
my luxaire is maybe 98ish
Old 11-08-2012, 08:16 PM   #13
Rewards Points: 31
luxaire furnace
what is a pressure switch it flash is 3 says pressure switch stuck open
Old 11-09-2012, 05:21 AM   #14
An old Tradesmen
Rewards Points: 7,816
The device to the right of your inducer. Has the blue and the white wire attached to it.
Old 11-09-2012, 06:36 AM   #15
Rewards Points: 31
pressuse switch
so its the thing with 2 wires blue and white and has a hose on it i took that off and i pulled vacume on it seems like it moves i will get a new one
hopefully thats it what happens my furnace kicks on run for awhile burner goes off and fan keeps blowing no heat
How to change blower speed in Luxaire furnace joef2 HVAC 2 11-25-2015 07:09 PM
Ruud Furnace issue grubslinger HVAC 16 09-14-2011 12:13 AM
Luxaire Furnace problem Orlo HVAC 32 01-03-2011 12:18 PM
Luxaire Furnace Won't Fire ChuckAnderson HVAC 14 12-07-2010 09:19 PM
Luxaire Furnace mobear HVAC 1 03-13-2005 11:54 AM
