Old 06-26-2009, 08:17 PM   #1
Default 1994 Comfortmaker RPJII
Burners were short cycling. Filter was very dirty and inside of furnace compartments were very dusty. I cleaned everything and installed a new filter and igniter. Furnace fires and keeps running now. Since it is summer I'm not comfortable this is a permanent fix! Could this have been the problem?
burntgoose is offline   Reply With Quote
Old 06-26-2009, 08:20 PM   #2
Probably.
SKIP4661 is offline   Reply With Quote
Old 06-26-2009, 09:15 PM   #3
old pro
That furnace has a bad history of cracked heat exchangers. Which may have been made worse by a lack of airflow/overheating. I would get a experienced tech to check it for safety reasons.
Old 06-26-2009, 10:26 PM   #4
Master Plumber/Mechanical
Those furnaces did have a problem with the heat exchanger popping the rings.
They also carry a 20 year warr on the exchanger.
Try to find a comfortmaker dealer.
www.gocomfortmaker.com
More On This Topic
Black walnut trees, used in landscape plans for their stately beauty and deep shade, grow in deep, fertile, well-drained soil and are tolerant of freezing weather conditions. Follow these steps to plant them. Read More »
Hi! I am Angela on behalf of expertvillage.com, and right now I am going to be taking about posture and the pains that can be induced from poor ergonomics and posture. Ergonomics is how your back is positioned and how your chair is structured. If it is... Read More »
Learn materials needed for silkscreening at home and how to screen print a shirt in this free video on silkscreening, or screen printing, clothing. Read More »
You should select furniture making plans primarily on your skill level. Plans that are too complex or which require special equipment may only serve to frustrate you. Fortunately, furniture making plans and furniture "how-to" articles are widely... Read More »
comfortmaker RPJII larry1 HVAC 9 02-14-2009 03:53 PM
'93 Comfortmaker RPJ propane furnace lifespan? Dawsonhope HVAC 5 11-21-2008 07:47 AM
comformaker rpjii shuts off to quickly nfalk HVAC 1 12-25-2007 04:12 PM
Comfortmaker RPJ - 1 Flash - Nothing ON olgranddad HVAC 29 01-02-2007 11:23 PM
Comfortmaker RPJII - 4 flashes - open high limit switch nisad HVAC 7 12-08-2006 01:33 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
