Old 08-28-2012, 08:27 PM   #46
1993 Comfortmaker RPG II Flame Sensor Not Working?
Originally Posted by Doc Holliday View Post
I only kind of glanced through this thread thus far, only now seeing that the problem was only after you changed the transformer. What was the problem before, why did you change the transformer?
I burnt out the old Transformer while using a test probe/w wire alligator clip on some of the Thermostat terminals on the Board, and being a Novice I toasted the old Transformer. Do any of you guys think I may have harmed the internal circuitry inside the Control Board for the Flame Sensor as well while doing this?
(I know I toasted the Transformer because of the obvious smell, so I replaced it and the AC worked just fine, but now I'm always having the Flame out)
Thanks for your help!
Northwoodslakes is offline   Reply With Quote
Old 08-28-2012, 08:27 PM   #47
I'm Your Huckleberry
I said I'd start there as electronics and electricity look good on paper but in actuality can be very moody, touchy feely, highly sensitive. I would at least give it a shot but you're right, it should work.
Again, why did you change the transformer in the first place?
Thanks.
Doc Holliday is offline   Reply With Quote
Old 08-28-2012, 08:28 PM   #48
How, I'm done with this guy. You can have at it.
Thanks.
Old 08-28-2012, 08:36 PM   #49
Originally Posted by how View Post
We've been basically getting you to test out other simple possibilities instead of just changing your 50A50-112, but as "Doc" suggests, it's probably time to take the plunge.
A pro at this time would be
confirming the DC milli amp of your flame sensor when the gas is burning.
checking if the 50A50 is even powering the flame sensor.
and making sure the gas valve is not still getting 24V after the furnace gas shuts off.
"how" I have a meter, but of course a novice. Can you tell me what and how to use it. I know how to set the dial for 120V ,and you have the 2 probe leads, one black, one red. Obvoiusly the One probe end goes on the Sensor Rod wire connection and the other end goes where? That plug where the Flame sensor wire goes into the Control Board is impossible to get anything to touch it. Is it too complicated to explain to me?
Thanks in advance "how"
Old 08-28-2012, 08:43 PM   #50
Hey, Doc, I told you guys I'm a NOVICE when it comes to electrical stuff! I'm learning from you folks! I appreciate all I can learn from all you experts!
You guys have solved many a problem, but mine seems more involved? I've done everything that has been suggested.
DO you guys think I may have toasted the Board when it comes to control of the Flame Sensor?
Old 08-28-2012, 08:56 PM   #51
"how" please don't jump ship on me like "Doc" did so quickly. If you can explain how a pro would test, I do have a Meter and would really like to try this before replacing the Control Board. You are exactly right, This sounds like what I really need to be doing. Do m just attach one probe end to ground and the other to the electrical connector on the Flame sensor? Then what do I look for in the Meter when it fires?
Is it too much to explain? I hope you can try, this will be the determining factor as you say. I think it is most likely the Board and would like to test it, if you can explain easily enough?
Thanks in advance.
Old 08-28-2012, 09:10 PM   #52
how
It takes very little of a voltage surge to damage electronic boards.
Your probe mishap with the transformer "experiment" could easily damage a 50A50.
I think the directions for doing a DC milli amp test on the flame probe circuit is questionable given your experience and probable test equipment.
Your reasonable options are
guess that the 50A50 is faulty and change it. (not with a used one)
or
get a pro to test it all & change what is needed.
This is not a good project for a novice to get involved with because of the safety issues and the additional expenses that your experimenting might cost you.
how is offline   Reply With Quote
Old 08-28-2012, 09:25 PM   #53
or
OK, "how" Thanks for your response. The furnace is 1993 vintage. A brand
new Board is expensive, and I don't believe this Furnace is even worth it. I will spend the $70.00 and get the used one from a reputable seller and exchange my Board with it. I'm thinking from all you've tried to teach me and yes I tried all things. I most likely fried it like you said.
Then if that does not work. I will hire a Pro and replace the entire Furnace. Perhaps time has come. I'm not going to throw good money at an Old Furnace. I think a new Board was like $300.00.
So thank you for your wisdom and expertise. (I certainly wish I knew more about the ins and out of electrical, but NADA) Thank you Friend!
Old 08-28-2012, 09:25 PM   #54
An old Tradesmen
Common of the 24 volt side.
Old 08-30-2012, 06:47 PM   #55
or
OK guys, Doc was right, I researched and found a universal replacement Board, the White Rodgers 50A55-843, brand new one for only $74.00. I appreciate all the great input from you guys on this DIYBoard. But please assure me that I do have the right replacement Board, (I've read on a few sites that maybe it isn't compatible? You read all kinds of crap on the Internet.) But I mostly have read it is and will be an easy install. Thanks to you in advance!! I will be so glad to get this aggravation fixed once and for all. What do you think "how"? I was so amazed to find this new Unit as you suggested. Only 74 Bucks!
Old 08-30-2012, 07:03 PM   #56
That is correct.
http://part-s-mart.com/white-rodgers...rol-board.html
Thanks.
The Following User Says Thank You to Doc Holliday For This Useful Post:
Northwoodslakes (08-31-2012)
Old 08-30-2012, 07:15 PM   #57
An old Tradesmen
Don't install that board. If you do, a nuclear power plant in China will blow up. Its a secret weapon invented by the KGB back in 1994. LOL... Just kidding around.
The Following User Says Thank You to beenthere For This Useful Post:
ben's plumbing (08-30-2012)
Old 08-30-2012, 07:51 PM   #58
That was just terrible, BT.
Thanks.
Old 08-30-2012, 08:19 PM   #59
What about the fact that the Burners stay on for approx. 5-6 seconds before flame out without the Sensor wire attached?
This is a design feature for the control board to allow the gas valve to open to light the burners so it can "see" the flame sensor. Without it allowing this it would never light. This is simply a timer in the control board. You indicated that the ground wires are hooked up in the junction box...are they all connected back to the main panel? Set your meter to Ohms and see what the reading is between the burner tube and the ground wire in the junction box. It should be the same as if you connect both meter leads together.
danpik is offline   Reply With Quote
The Following User Says Thank You to danpik For This Useful Post:
Old 08-30-2012, 10:43 PM   #60
hey bt thats just not right..lol but i liked it..
Random Flame rollout on Gas Furnace Albe HVAC 21 03-03-2012 01:35 PM
New flame sensor not working tryintofixit HVAC 4 10-23-2011 04:03 AM
York Diamond 80 Intermitten Flame Setdyi HVAC 37 12-01-2010 06:01 AM
Ruud furnace issue on upgrade board and flame sensor rubberman HVAC 22 01-16-2010 12:34 AM
comfortmaker flame sensor big ron Appliances 1 11-02-2007 10:20 AM
