1993 Basement HVAC Question - HVAC - Page 3 - DIY Chatroom Home Improvement Forum
Old 05-11-2013, 01:45 PM   #31
An old Tradesmen
Rewards Points: 7,278
Originally Posted by Daugela View Post
That makes sense. I thought heat pump warranties were transferable? Well at least if the original owner purchased the transfer option. I can't find any facts about "service facts" on their website.
I just pulled up the SF for a 16i. Doesn't have the extended data in it.
Old 05-11-2013, 01:50 PM   #32
An old Tradesmen
Well now, 4 ton it is....I will have to check this with other manufacturers. In general, do most 4 ton have this rating?
Each manufacturer is different. Some will be less, some will be a tad more.
All of them will lose capacity as the outdoor temp increases.
If you really want a 20i. Then get a new one through a dealer, and get the 10 year parts and labor warranty.
Old 05-11-2013, 02:33 PM   #33
Rewards Points: 892
So I'm on other manufacture websites like Goodman, and see there are different charts for high stage and low stage. Their 4 ton DSZC18041 has a lower BTU capacity then the high stage.
Daugela is offline   Reply With Quote
Old 05-11-2013, 02:44 PM   #34
Rewards Points: 892
Nevermind. I think I figured it out that this unit for example has two stages of cooling for hotter days compared to milder days...
Old 05-11-2013, 03:14 PM   #35
An old Tradesmen
All 2 stage units have 2 ratings for the same conditions.
Old 05-11-2013, 03:20 PM   #36
Rewards Points: 892
Where I'm getting confused is the CFM per each rating. Even though I did a load calculation, I didn't do anything with CFM. The chart on the Goodman website for this particular model has different capacities for different CFMs.
Does each unit put out different CFMs based on duct design? How does it work in relation to the chart when I choose my unit?
Old 05-11-2013, 03:27 PM   #37
An old Tradesmen
The York info I posted was at the highest rated CFM. It had 2 of CFM ratings.
For your area, use the highest or second highest CFM rating. CFM is chosen to meet the shr requirements of the home. shr= Sensible Heat Ratio.
Manufacturers use what ever CFM that will get then their AHRI rating. They then either test it at other ratings, or use computer simulation to extrapolate BTUs ratings at other CFMs.
Old 05-11-2013, 03:46 PM   #38
Rewards Points: 892
But what correlation if any does the CFM have from this chart by me choosing the highest one (1969) on me designing the duct work?
Old 05-11-2013, 04:13 PM   #39
An old Tradesmen
I don't know what chart your referring to. A room by room load calc tells you what CFM each room needs. this is based on the sensible and latent load of the rooms. A manual D is then used to size your duct work.
Do I need a HVAC return vent in basement? westing HVAC 13 04-03-2014 01:43 AM
Basement wall insulation / remodel question Chokingdogs Insulation 2 03-14-2013 12:26 AM
Newb DIY'er -basement drop ceiling question mike dub Remodeling 3 02-18-2013 07:37 AM
Do I need to add HVAC ducts to my below grade basement rooms if my daylight basement rooms already have HVAC supplies and returns? cmgoss HVAC 1 06-29-2011 05:12 PM
Basement Insulation / Vapor Barrier Question Krendler Building & Construction 0 02-24-2010 05:29 PM
