1989 Heil Furnace Question - HVAC - DIY Chatroom Home Improvement Forum
Old 01-15-2010, 05:18 PM   #1
1989 Heil furnace question
I have a question for someone familiar with Heil furnaces.
farmer 85 is offline   Reply With Quote
Old 01-15-2010, 05:24 PM   #2
The blower motor runs continuously. Is this a pressure switch problem?
Old 01-15-2010, 05:49 PM   #3
Hvac Pro
yuri's Avatar
Rewards Points: 1,844
No. Post the model #. ANY 20 yr old Heil should be THOROUGHLY checked for a cracked heat exchanger. Is the burner working/producing heat?
Old 01-15-2010, 05:52 PM   #4
Model # is NUGK100, yes the burner is producing heat.
Old 01-15-2010, 05:55 PM   #5
Hvac Pro
yuri's Avatar
Is the thermostat fan switch set to ON, should be at AUTO. Did you replace the thermostat recently. If not the relay and circuit board may be faulty. Before I spend $$ on it the heat exchanger should be inspected. Lots of failures with them.
Old 01-15-2010, 06:04 PM   #6
fan is set to auto, the thermostat is only six months old... a technician thought might be the pressure switch. What's does that do???
Old 01-15-2010, 06:11 PM   #7
Hvac Pro
yuri's Avatar
Proves that the ventor fan is running.
Old 01-15-2010, 06:30 PM   #8
Does that one have the dial type limit yuri? The one with the continous fan button?
Old 01-15-2010, 06:43 PM   #9
Hvac Pro
yuri's Avatar
Not sure, would have to get him to post pics of the burner area and above it. Sold a G71-70 and XC16 A/C yesterday. Nice stuff, over $10,000 sale. Too bad I don't get the salesguys commission.
Old 01-15-2010, 06:47 PM   #10
what is the ventor fan? my blower motor is running all the time
Old 01-15-2010, 06:49 PM   #11
i have the manual... it has a dial type limit switch
Old 01-15-2010, 07:24 PM   #12
Some of those dial type limits have a white knob that turns the fan on all the time. Don't remember if pushed in is on or pulled out is on. Change the position if it has one.
Yuri- Our electric company is doing their $500 per ton rebate again this year on high Seer equiptment so that will help next month. Last year they had that program, the $1000 back from Lennox and the $1500 tax credit all at the same time. Same thing this year which is sweet. The combined programs saved our customers over $250K in replacement cost last Feb and kept the change out crews very busy. Most were G71's or G61's and Xp19 combo's. No commission for us either.
Old 01-15-2010, 07:25 PM   #13
Hvac Pro
yuri's Avatar
Post some pics of the burners and furnace with both doors off. There are dozens of different Heil/ICP units and variations of them. The ventor fan pushes the smoke to the chimney if that type is yours. The dial type fan/limit control may be sticking or the contacts welded shut or a fan relay is faulty depending on your model.
Old 01-15-2010, 07:29 PM   #14
Hvac Pro
yuri's Avatar
Marty;
It is either a feast or famine for the salesguys and I am not sure I could put up with all the tire kickers and arzh*les who want to give you the "hairy eyebrow" and nickel and dime to death. We have LONG term customers who pay a bit extra but we silicone all joints and do TOP notch work. I may do sales if the knees give out.
Gas furnace exhaust vent question nowell HVAC 7 01-30-2012 08:31 AM
Make up ventilation through return on furnace question creamaster HVAC 8 09-27-2009 04:53 PM
Heil furnace won't start - just a click and a hum MrGookat HVAC 4 01-06-2009 07:53 PM
Heil furnace issue sbriggs_1 HVAC 19 12-05-2008 05:07 PM
my ac keeps blowing boards on my heil furnace sally HVAC 2 07-23-2005 07:14 PM
