1986 Reclaimer 80 Furnace - HVAC - DIY Chatroom Home Improvement Forum
Old 12-11-2011, 08:50 PM   #1
1986 reclaimer 80 furnace
Hello, I have an 86 Reclaimer 80 NG furnace. Up until two days ago it was running fine. When I started trying to diagnose why the blower stayed on constantly, I noticed when I shut off the fuse switch and turned it back on the blower instantly started and the pilot would light.
I did some research via Google and found the problem I was having. They recommended changing the filter and resetting the relay. When I reset the relay I noticed one side reset the other did not (the side wired to the blower). I even tried resetting it under power. Pushing in the reset caused the blower to stop, but as soon as I released it came on again. I tried it again and now I can't get the blower on at all. Does anyone know where to find parts for this furnace? I am assuming I need a new relay.
I recently purchased the house. I forgot to change the filter before start up. It was completely clogged. Thanks for any help.
kentaysdad is offline   Reply With Quote
Furnace Model # Feh-015-04 clicking but not turning on? haimei HVAC 1 12-14-2010 05:01 PM
Payne PG9YAB high efficiency 95% furnace water draining problem jchen64 HVAC 9 12-06-2010 06:42 PM
Carrier Infinity 69 Trouble Code 42 bodya1 HVAC 4 12-05-2010 06:43 PM
Problem with Trane gas furnace quovadis HVAC 17 12-22-2008 01:12 PM
Olsen BFL 120 Furnace DaleB HVAC 12 12-19-2008 10:42 PM
