Old 11-07-2007, 09:01 AM   #1
1969 Reznor garage heater, worth using or buy new one?
A neighbor gave me his old garage heater. He hasn't used it in the 10 years he's lived in the house. I'm trying now to decide if it's worth hooking up or if it should just be scrapped. I want to heat a roughly 3-car, 1-storey space for my workshop.
The label on it says: Reznor/ITT Model XA-100 ser 2. 80,000 BTU, serial number UC933N43. From the Reznor site, the serial number tells me that it was made in roughly 1969.
I need it to run on propane. The label says it's natural gas, but there were no lines running to it in my neighbor's garage. He says there were propane tanks out back when he moved in...but there were no propane lines running to it either. So, I'm not sure what fuel it actually runs on.
I've tried a few searches online to find Reznor parts suppliers to see if a propane orifice is available. I haven't come up with much. And the two I contacted via their web sites haven't responded.
Any advice would be appreciated. Thanks in advance.
Tim
timp is offline   Reply With Quote
Old 11-07-2007, 11:01 AM   #2
They have a web site. Try getting info there or contacting them.
http://www.rezspec.com/page-14_See_all_folders.html
cjett is offline   Reply With Quote
Old 11-07-2007, 06:11 PM   #3
scotch on the rocks
hvactech's Avatar
count the burners and divide the number by the BTUs, something like 80000 btu's/4 burners =20,000 btus per burner, then pull one of the orifices out and look at the numbers, there are plenty of burners orifices charts all over the net, the chart tells you the orifice output for NG or propane.
orifices in many cases are interchangable, you dont need a reznor orifice, could be any other brand, you also need a new sprig for the gas valve.
if you post the orifice number I could tell you whats the output.
good luck
hvactech is offline   Reply With Quote
Old 11-08-2007, 10:34 AM   #4
cjett: I've been to the Reznor site to check for manuals and parts availability. According to their site, parts aren't available. So, I guess I'll need compatible parts from another manufacturer or old stock for some supplier.
hvactech: I'll disassemble and check for the orifice numbers like you suggested...it will probably have to be this weekend. Is there a way to tell by looking at them if they're for NG or propane? Also, let's say they are propane, how do I know if they're in good shape or need to be replaced?
Thanks,
Tim
Old 11-08-2007, 08:41 PM   #5
scotch on the rocks
hvactech's Avatar
orifices dont go bad, you may have spiderwebs, bugs or dust in it, nothing compressed air cant clean, there are numbers stamped on the orifices post them and I'll tell you what its rated for.
More On This Topic
Ice fishing is a popular pastime in the northern states where the lakes and rivers freeze. The ice fishing houses range in sophistication from a little pup tent to a fully built, functioning home. There are several ways to heat the ice fishing house... Read More »
Hi! This is David from expertvillage.com from Big Easy Catering Company. We just deep fried the turkey and now we want to go over a few safety tips that people ask me about all the time. First make sure your propane is securely turned off. We don't want... Read More »
Hi, my name is Mark Delgado with American Auto Service for Expert Village. Any time that you remove a bad compressor, you have to flush the AC system out, replace the orifice tube and replace the dryer or the accumulator. You are either going to have a... Read More »
When you're trying to save money each month in energy costs, one of the first and best places to make a change is in the hot water system of your home. Homeowners can end up spending hundreds of dollars more per year than they should as a result of an... Read More »
History of Metal Forging
History of Metal Forging by Expert Village
On behalf of Expert Village, I'm Terry and I'm here today to show you the workings of a forge. The purpose of a forge was invented so that we could heat iron and ores so that we could form metal, make tools, weapons, the original reason was for weapons... Read More »
Water heater problem bear1957 Plumbing 23 11-01-2007 04:53 PM
Installing a tankless water heater ? bdalekid Plumbing 3 02-26-2007 08:26 PM
Wiring electric heater in bathroom PatSea Electrical 5 01-06-2007 10:40 PM
Baseboard heater Help! jweinstock Electrical 6 10-28-2006 05:01 PM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 11:31 AM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
