1928 Octagon Furnace - HVAC - DIY Chatroom Home Improvement Forum
Old 10-14-2012, 09:11 AM   #1
1928 octagon furnace
I own a two family home and my octagon furnace needs to be re-ignited. Does anyone know how I can do this? Do I simply take a lighter up to it and light it?
Schayban16 is offline   Reply With Quote
Old 10-14-2012, 11:37 AM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,060
Ayuh,... What's an octagon furnace, 'n what does it burn,..?? Fuel,..?? Gas,..?? Coal,..??
Bondo is online now   Reply With Quote
Old 10-14-2012, 11:43 AM   #3
Rewards Points: 13,458
Make, model?
Is Oxtagon the shape of it or the make?
Got a picture.
Old 10-14-2012, 11:44 AM   #4
Rewards Points: 6,652
Good old Octopus furnace. I would have it inspected by a HVAC co. before relighting. Also make sure you have CO detectors in the home.
We got rid of the one in our house shortly after we moved in, due to it was beyond its timespan, and killed on gas.
I left ours running on pilot all of the time, due to they are a pain to relight.
Old 10-14-2012, 12:51 PM   #5
how
Rewards Points: 1,104
Wow..
That's must be well over 50 years old. Most of the ones I ran into died years ago.
They usually have a manual baso safety switch that needs to be engaged just to get the furnace to work.
You'd better send us a picture of the furnace controls with the access cover open.
And yes, an exchanger inspection and CO test is needed!
how is offline   Reply With Quote
Old 10-14-2012, 01:30 PM   #6
Rewards Points: 582
don't waste any time with that bomb ..get estimates to replace it...,,because the truth is it should have been replaced yrs ago..ben sr
The Following 2 Users Say Thank You to ben's plumbing For This Useful Post:
COLDIRON (10-14-2012), gregzoll (10-14-2012)
Old 10-14-2012, 01:40 PM   #7
Rewards Points: 610
That Octopus is extremely inefficient and the heat exchanger is gasketed and likely leaking combustion fumes into supply air ...extremely dangerous!! Carbon Monoxide Poisoning very real liklihood. Do you get headaches during heating season? Replace with high efficiency condensing gas furnace ..will save you 60%!! PLEASE get rid of it!!
techpappy is offline   Reply With Quote
The Following 2 Users Say Thank You to techpappy For This Useful Post:
Old 10-14-2012, 11:02 PM   #8
REP
Wow,,, you must be very wealthy to run that thing.
After you have a real manual "J" and a manual "D" done,the new furnace wil pay for itself (whatever it costs) in a very few years.
REP is offline   Reply With Quote
The Following User Says Thank You to REP For This Useful Post:
ben's plumbing (10-15-2012)
Furnace Model # Feh-015-04 clicking but not turning on? haimei HVAC 1 12-14-2010 05:01 PM
Payne PG9YAB high efficiency 95% furnace water draining problem jchen64 HVAC 9 12-06-2010 06:42 PM
Carrier Infinity 69 Trouble Code 42 bodya1 HVAC 4 12-05-2010 06:43 PM
Problem with Trane gas furnace quovadis HVAC 17 12-22-2008 01:12 PM
Olsen BFL 120 Furnace DaleB HVAC 12 12-19-2008 10:42 PM
