Are 16X25X4 Filters Universal Size? - HVAC - DIY Chatroom Home Improvement Forum
Old 09-13-2015, 02:07 PM   #1
First Home
Rewards Points: 320
Are 16X25X4 filters universal size?
Hi guys, I bought a new house, with a closing date upcoming in about 2 weeks, during the home inspection the inspector showed me the current filter was CLOGGED, likely unchanged in the 4 years the furnace has been installed (likely because there expensive)
Anyways, I found them much cheaper online vs buying in the bix box stores, but the sizing is a little different, luckily he took alot of pictures and I can read the size of the filter currently installed in the furnace.
15 1/2" X 24 1/2" X 3 5/8"
And the ones Id like to purchase are Honeywells:
15-7/8" X 24-7/8" X 4-3/8"
The model number he wrote down for the furnace, I could find nothing referencing filter size
Model Number: GMVC950704CXAC
Serial Number: 1103103954
To me from the picture of the filter installed it looks like I may have enough room for the almost extra inch width of the Honeywell filters. Id like to purchase the bulk pack of 6 which bring the price to bout $15 each, but if they dont fit....
Cheers guys and thanks
KevinEF7 is offline   Reply With Quote
Old 09-13-2015, 02:24 PM   #2
Rewards Points: 7,724
I don't think they're universal.
You could probably find a generic filter that's the same or a little smaller than the honeywell.
This furnace should be thoroughly inspected and cleaned as soon as the house closes. The heat exchanger, variable speed blower, or limit switch may have been damaged by the lack of maintenance.
user_12345a is offline   Reply With Quote
Old 09-13-2015, 02:29 PM   #3
Rewards Points: 5,336
There are no universal size filters. That would imply, one size fits all furnaces. What there are, are various standard size filters.
Ron
B. Franklin 1759
Old 09-13-2015, 02:36 PM   #4
Rewards Points: 1,300
Request access to the house and take an actual measurement.
SeniorSitizen is offline   Reply With Quote
Old 09-13-2015, 02:48 PM   #5
First Home
Rewards Points: 320
We do have a visit but its not for another 10 days, was hoping to place the order before then
What I meant by universal size was, do all furnaces that require a 16X24X4 filter have an opening big enough to fit most if not all manufacturers slight differences in sizing.
If this honeywell I am looking at presumably would fit, than the one I am pulling out must not have been tight to the sides to create a good seal since there is a decent different in those measurements aswell. Does the model # give any sort of clue to needed filter size to the more veteran HVAC guys?
If I have to wait until I am able to return for another visit before closing to measure exactly, ive got no problems with that, not looking to waste any money, just looking to be a responsible first time home buyer
Old 09-13-2015, 03:17 PM   #6
Hvac Pro
yuri's Avatar
Rewards Points: 2,296
There are 4" and 5" filter boxes. Honeywell is a HUGE company and I doubt they will label/build their 4" filter too big and have complaints. Are you sure the 4 3/8" is not describing a 5" filter?
Only way to know for sure is to measure the opening as those filter boxes are made by different companies and some may allow for a bigger than 4" filter and others not.
Old 09-13-2015, 07:11 PM   #7
First Home
Rewards Points: 320
It is indeed a 5" filter that I found, they had it in the 4" section though, back to hunting I guess
Old 09-13-2015, 07:22 PM   #8
Rewards Points: 6,652
They are expensive. You can get a 3 pack of the Trions for $60, which comes out to be around $20 a filter. http://www.amazon.com/s/ref=nb_sb_no...furnace+filter
Amazon is going to be your cheapest way to go.
Old 09-13-2015, 08:44 PM   #9
Rewards Points: 34
One additional factor is the MERV rating.
When you shop for big filters you'll have different MERV options.
Dan
djlandkpl is offline   Reply With Quote
Old 09-14-2015, 07:11 AM   #10
Hvac Pro
yuri's Avatar
Good Point. That furnace has a V drive ECM motor so you can use a higher Merv filter. I would recommend a Merv 8 or 10. Anything higher and we would need to see the duct size if it is large enough plus they get very expensive.
Old 09-14-2015, 08:27 AM   #11
Rewards Points: 163
Home Depot sells a two pack of 16X25X4 Honeywell Merv 8 filters for about $38. That's what I use.
kb3ca is offline   Reply With Quote
The Following User Says Thank You to kb3ca For This Useful Post:
Chris130 (09-14-2015)
Old 09-14-2015, 10:50 AM   #12
FIDO...
Rewards Points: 241
^^^ Me too. Once in a while, Home Depot puts those Honeywell two-packs on sale for a pretty good price, so when I notice that, I stock up on a couple sets.
Cheers, Chris
Chris130 is offline   Reply With Quote
Old 09-14-2015, 09:50 PM   #13
Rewards Points: 164
The problem is if you measure one of those 16X25X4 Honeywell filters, its really 15 3/4 X 24 3/4 X 4 3/8. I had a hellva time finding a generic replacement. I think Honeywell does that to thwart buying other brands.
partner is offline   Reply With Quote
Old 09-15-2015, 12:36 AM   #14
They are already aware of the size of the filters. The reason for difference between the duct size and the filter size, is so that the filter can still be removed, even if the unit is running.
Old 09-15-2015, 06:50 AM   #15
First Home
Rewards Points: 320
Appreciate the information guys, unfortunately here in Canada hd charges $44 each for this size filter!!
Sink Size Specs - Advice needed donvaz Kitchen & Bath Remodeling 1 08-12-2012 01:39 PM
wire size for 1575 inverter 15' from battery bluemoonshine Electrical 8 12-28-2011 09:49 AM
Proper trunk/duct size? gjones HVAC 7 12-06-2011 07:18 PM
Wiring Size Calculations for New Service CorinthWest Electrical 7 12-07-2010 11:36 AM
What Size Crown Molding? Jim McClain Interior Decorating 1 10-04-2010 07:16 AM
