Old 08-01-2009, 12:21 AM   #1
JMK
$1440+ labor only repair on 3 yr. old Goodman unit!?!
Please, please, help!
I sure could use some advise, because I'm disabled living in AZ (115 degrees) and I've had 2 different companies come out both telling me the compressor is bad/going/needs to be replaced, but differed in other things they said (One contradicting what the owner told me when I scheduled the call.) In essence, new compressor, new fan, new blower motor, and reversing valve (not sure about this one, but it was mentioned). What else is there?
The unit is a Goodman heat pump that was put in through the housing rehab program because I'm low income and disabled. I have a lien against my house for the costs. (I had no choice in what unit was put in.)
The problem occurred yesterday when what ended up being a piece of insulation that came loose and blocked something restricting airflow intake from the return? I first called the original installer who'd been out in Dec. 2008 to repair a loose thermostat wire, but from the invoice checked freon and other stuff. - all was ok. They couldn't come out until Monday, so I had to call someone else. But he did tell me the insulation falling out was probably what happened which I immediately told to the first contractor that came out. I did use the a/c when it got to 85 degrees, but when it cooled bit I'd shut it off. Both technicians said this is NOT what caused the compressor to fail. (one said it was the fan, the other said they just sometimes go.)
After looking at the unit, Tech. #1 tells me the fan didn't work until after he hit it, the compressor is shot. We monkey around with the warranty and scheduling, because this needs to be done tomorrow. So I sign the contract and give him half ($714) on a credit card. Then he sees the unit is still not sucking well from the return and tells me I might have a collapsed duct and can he get in the attic. I know I have galvanized duct work and not that flexible stuff and tell him so. He takes the cover off the AC unit and, sure enough, there's the piece of insulation! I have him test it again and he says the readings are actually worse now! I need a new compressor and fan (Labor is over $1400, parts are warrantied.)
The 2nd company (BBB listed) that came out was even worse. I spoke with the owner to schedule the app't and replace the insulation and check the compressor. He said " compressors either work or they don't". I looked at his website and it states "FREE second opinions on compressor replacements", and FREE service call with any A/C repair" (which I thought would go towards replacing the insulation and is why I called him).
The tech comes out and says I needed a new compressor and blower motor ("it felt hot" but was working - jeez, it's on the roof and it's 115 degrees outside - everything feels hot up there). I asked him if was going to replace the insulation and he says it needs a metal strip which he doesn't have because it can't just be reglued for a cost of $120, I said I hate to pay for another service, I thought they could fix it now. Then he says $90, then walks to his truck and brings out some tape and says he'll tape if another $60 (or total of $120 for a repair that he says won't work.) To be honest, there was some language barrier, but it wasn't making sense, so I called the company while he was here and said I'm not comfortable paying $60, and then another $60 to have him come back and put the insulation back on and needed clarification. The girl I spoke with said she couldn't make that decision, the owner wasn't available, but she'd have him call me. I said I'd be more than happy to work it out and pay , but not until I understood what I was getting or what should be done.
I explain all this to the poor tech and he calls and speaks with the owner. Then the owner calls me up screaming how "He hears I don't want to pay!" I attempt to calm him down and ask him, well you told me earlier a compressor either works or doesn't, the a/c is working as good as it ever did as far as I can tell, so do I need a compressor? He says thats up to me to decide. Then I mention what is on his website and he says the $90/$120/whatever already has the service call deducted from that. (Not that I want to, but I think I could reattach the insulation w/o too much problem.) But $180 to reattach a 31" x 31" piece of insulation seems excessive. I ask the owner, well how much is it to correctly attach the insulation because I got 3 different prices and he can't tell me and mentions a kit needs to be used? Elsewhere on the unit, I saw another piece of insulation attached with 4 sheet metal screws with large washers to hold it in place (The first tech said that was bad for some reason.)
So I'm paying $39.95 for someone to take the piece of insulation out and hook up some gauges - that's okay - though I should have been giiven the option to get it reattached w/ a quote. (If the company is honest and refunds my credit card, which I think they'll do.)
But now I get charged another $60 for nothing except get yelled at because I couldn't make sense of what they were saying.
And I still don't know if the compressor is really bad and should be replaced, if it's the fan, blower motor, reversing valve, etc. too?
I did go up and read the gauges the 2nd guy used and he did do a more thorough check with a temp gauge at the return and registers (said temp difference should be 20 degrees but it's only 15 degrees difference) and it did look like the readings were less than what was on the Heat Pumps label.
But it seems to be working fine now, but I'm terrified it will suddenly break in this heat. I can't keep paying $60-$75 for someone to come out nor can I afford to basically pay for all that labor on 3 year old heat pump (the unit was line itemed at $5457 when installed). I did buy an extended warranty for $100, but that only covers $800 in labor, which would help if the work is truly required, but still, the reason I got this is because I'm low income, disabled, and living in a crappy neighborhood. I never had a problem in 11 yrs. with my old 1970's heatpump nor has my electric bill dropped, but I'll have to look at the kilowatts I was using.
Believe it or not, this is the short version of what happened and the stuff I was told.
Can this possibly be right and happening!!! Please help, I'm terrified my AC will break and I can't take days in this heat (I have no where else to go and have 2 elderly dogs) to get quotes to repair or keep paying for the service calls! I don't know who to believe. What should I do - I'm panicking?
I'm thinking that if it goes, I will put everything in my car and go to my Mom's in WI until fall when I can take my time to deal with this, but this option presents several problems, too.
WARNING: Beware of The Housing Rehab Programs (HUD money given to cities to help low income people in bad neighborhoods.) They put a lien against your house, make you have work done that's not needed, and you get a bunch of junk and shoddy work!)
JMK is offline   Reply With Quote
Old 08-01-2009, 12:39 AM   #2
Master Plumber/Mechanical
With the unit only being 3 yrs old the compressor should be under warranty. Not the labor and to replace the compressor shouldn't exceed $800.
Google Goodman and go to there web site and try to find another dealer the guy you are dealing with seems like a real ass clown.
15 deg different from supply/return is pretty good on a 115 deg day.
Find a better tech
Talk to friends and neighbors and see who they use.
John Wayne once said "Life is tough and it is even tougher if you are stupid"
Arcoaire and Trane Dealer
Old 08-01-2009, 06:15 AM   #3
An old Tradesmen
Find a better tech
I guess you know the cost of living where this company is from.
OP:
Doubtfull the compressor is bad. Wait till you can get the guy/company out that installed it.
Old 08-01-2009, 06:15 AM   #4
JMK
Find a better tech
Both quotes came in at $1200+ and $1400+, no one has been able to recommend anyone, but unlicensed mexicans, and I don't want to go that route, because in order for the warranty to be in effect it must be serviced by someone licensed. I'm wondering if they're not trying to screw people because it's so hot and I'm hoping to put it off until fall when I can take the time to call around.
Thanks, I will try contacting Goodman.
Old 08-01-2009, 09:55 AM   #5
I would say that your original problem was the insulation that had come loose. Your system is probably grossly overcharged due to the airflow restriction. I would recommend calling a major brand {lennox, trane, carrier} dealer to check your system. You will have a better chance of getting honest service work.
SKIP4661 is offline   Reply With Quote
Old 08-01-2009, 10:27 AM   #6
Hvac Pro
There may be nothing wrong with the unit now.
Sequence of events:
1) insulation falls off and restricts return
2) Motor overheats and cuts out on thermal overload, evap coil may have froze up
3) Customer shuts it off, insulation removed
4) Coil thaws out, motor cools off and resets
5) Unit restarted and all okay
6) Rarely does a motor or compressor get permanently damaged by one incident (scrolls can handle liquid slugging better than recips)
Sounds like dishonest contractor trying to take advantage of customer
PS: The compressor and motor may have a shorter lifespan now but if they are working and unit is cooling okay now then they don't need replacing. If they fail in the future that is another story.
Old 08-01-2009, 12:42 PM   #7
JMK
Thanks all of you! I feel better now and calmed down. It's just so hard to find a honest contractor out here. Neither technician replaced the insulation. Should I just do it myself? It didn't really look all that hard if I can tell well it should go exactly. I wasn't up on the roof when the guy found it, but the top cover came off and he just pulled out the insulaton. (I know to turn the power off.)
It was a very bad day, ktr who replastered my pool was scheduled to come that day for a crack and I'm being ignored for some rain gutters I had installed a month or so ago, that leak behind the gutters very badly. (They want another $160 to add a metal strip along the edge.)
I just don't understand how people can do this to one another. I'm orig. from WI and this type of thing never happened. Checking with the registrar of contractors and the BBB seems to be a waste of time.
Or am I being taken advantage of because I'm a woman? ( i hate to think that that's still the case.) Last winter, I painted the exterior of my house (took me 6 mos.) but I know I did a better job than another I could have hired.
Thanks again you all!
Old 08-01-2009, 12:57 PM   #8
Hvac Pro
The insulation should be replaced. Some contact cement or silicone on the insulation backing and unit and then some screws with large washers will work just fine. Dishonest contractors prey on the elderly and anybody else they can without regards to gender. I nailed a dishonest chimney guy trying to rip off an elderly lady and just about put him out of business. "What goes around comes around" and I am sure he will fall off a roof soon if he hasn't already.
Old 08-01-2009, 04:39 PM   #9
JMK
Well, I'm only 48 yrs. old, but feel like 80. I've had several surgeries(knees) and currently have a broken shoulder, but I still eventually climbed up on the roof so I could see what was going on. It's just very difficult for me. I used to be able to do a lot of work myself. I just don't know how to avoid the dishonest ones. I usually give people the benefit of the doubt and figure "most" are honest, but I think out here "most" are not. I really want to get my house fixed up and move back to WI to care for my 86 yr. old Mom. More pressure. But people are better up there for the most part.
Thanks, I think I will try and put that insulation on myself, if I can see exactly where it goes. Hopefully they be some glue residue where it came off of.
Old 08-01-2009, 06:54 PM   #10
OP:
No I don't know the cost of living there Been.. Why don't you tell me.
Then again, even a Piece Of Sh!t Goodman comes with at least a 5yr compressor warr. That's my point.
He said that he had some sort of warr program that cover $800. If you or any one here can't replace a compressor for less than $800 (labor) then first, the customer is getting a big ol' screwing, Second, who ever is doing the job needs to go back to school.
I also doubt the compressor is bad.
Old 08-01-2009, 07:31 PM   #11
An old Tradesmen
I don't see hat he has any labor warranty.
Just the factory part warranty.
Which doesn't include contactor, run cap, liquid line filter drier,R22 disposal fee, new R22.
Being on a 135degree roof changing a compressor is worth more then 800 dollars.
While the compressor probably isn't bad. The fee they wanted was proper.
So yoou would just slap a compressor in, and leave all the old componets, and only do a 5 minute vacuum.
Old 08-01-2009, 08:00 PM   #12
The man states it above..$800
How would you know the fee is fare do you live in this mans area and know the cost of living?
That kind of fee here would not fly.
As far as the compressor, No I would not just slap a new compressor in. A proper diag would be done first and a fee up front. Really love the guys that can't help out a disabled brother..just screw and screw $$$ out of them. Disabled, veterans and senior I cut my labor in half and YOU?
135 deg on the roof..yea so it's hot..
Just keep in the back of your head that you are not in iraq with body armor, weapon, a vehicle with no a/c, then remember you are here. Free to do what ever you want to do. Help those who can't afford us or not, it will always come back around.
Old 08-01-2009, 08:42 PM   #13
Hvac Pro
Our poster is a woman. Smart gal and not afraid to fight for herself.
Old 08-01-2009, 09:06 PM   #14
An old Tradesmen
She isn't where you are.
Lot of areas in AZ sre high cost of living.
I haven'y changed out a compressor on a split unit with the condener on the ground for less then 1000 bucks for 4 years. If I didn't do the original install. And yes, thats with the compressor under warranty.
Only contractors in her area, can give her an appropriate price.
Contractors on the internet not in her area. Can only fuel someones doubts on price. And prolong the task of gettinga system repaired.
She is in a hurry. And picked 2 companies, that have techs 2 candles short of the dimmest bulbs on the christmas tree.
Old 08-01-2009, 09:07 PM   #15
Thanks Yuri. Man I overlooked that. Sure sounds like a strong gal.
I had a disabled guy last year that gave me a camera because he couldn't get out and watch. Had me take pics of the gauges before and after because I said it was low on charge.
More On This Topic
Replacing insulation is an easy and money saving way to reduce your home's heating and cooling costs. People with good fiberglass insulation installed will never have to replace the insulation again. The easiest time to replace insulation is during home... Read More »
You found the house of your dreams, and all the inspections, mortgage paperwork and contracts are done. It's time for that final walk-through before heading off to the closing. Don't take a final walk-through lightly; it's your last chance to spot... Read More »
Hi! My name is Joshua Lindsey with CFM Building Science Solutions. On behalf of Expert Village, we are doing a frame walk and insulation inspection on this home. The thickness of our insulation is going to make a difference in the R-Value. So if we have... Read More »
Your home's heating and air conditioning system (HVAC) is one of the most important elements involved in enjoying your home. Besides providing a comfortable environment, your HVAC also helps to maintain your health by protecting you from extreme... Read More »
Hi! My name is Joshua Lindsey with CFM Building Science Solutions. On behalf of Expert Village, we are doing a frame walk and insulation inspection on this home. We've already talked about how 25 percent of my wall is 2x4 is already a low R-Value. Okay... Read More »
Can't get unit to turn on need electrical help please-wiring diagram included igotshocked Electrical 32 04-15-2009 11:46 PM
Sub is swapping Amana for Goodman Dragon HVAC 22 02-04-2007 08:54 AM
Repair hole from AC unit MSC Building & Construction 5 04-15-2005 11:36 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
