14 Below Zero Here And My Furnace Exhaust Is Frosting Up - HVAC - DIY Chatroom Home Improvement Forum
Old 02-03-2007, 12:31 PM   #1
Rewards Points: 129
14 below zero here and my furnace exhaust is frosting up
It vents through a chimney duct to the roof and the frost around the pipe is very large where it exits at the chimney. Should I be worried?
wease is offline   Reply With Quote
Old 02-03-2007, 12:42 PM   #2
Electrical Engineer
Is it a 90% efficient furnace?
rakes9720 is offline   Reply With Quote
Old 02-03-2007, 01:18 PM   #3
Rewards Points: 129
I believe so. It's a sealed combustion unit.
Old 02-06-2007, 09:27 AM   #4
Electrical Engineer
If the ice covers/blocks the vent pipe, it will prevent the pressure switch from making, and you will see the associated diagnostic code in the furnace. If it does this, then you have to clear the ice. It could possibly cause other problems if it gets blocked, but you don't have to clear it unless it causes a problem.
Old 02-06-2007, 10:48 AM   #5
Rewards Points: 129
Thanks. I just don't want any exhaust in my home.
Old 02-06-2007, 03:10 PM   #6
Electrical Engineer
The safety switches in the furnace will prevent this.
Old 02-06-2007, 04:24 PM   #7
Is the "chimney" made of bricks or metal pipe?
redline is offline   Reply With Quote
Old 02-06-2007, 04:55 PM   #8
Rewards Points: 129
Chimney is all stone with pvc coming up.
